SOURCE: Setting Clock for JVC-KD-G420
Here is the link for the manual http://books.jvcservice.com/download/289413083/38360.pdf page 7 Hope this helps :)
SOURCE: jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
SOURCE: clock setting on jvc kd-g140 car audio deck
Press the Mode button (M) and the display will flash mode. Then hold the select button (SEL) until it changes to display something else. Hit left and right seek until you find clock M and clock H. Hit select again and use the volume button to change the time! Took me two freaking hours to figure that **** out.
