Mine 2010 dream maker stopped working all of a sudden. I could hear a click as if it was trying to start. I checked the fuse and it was blown. I replaced it for $3.33 and all is working now.
Not too familiar with that brand but check all fuses with ohm meter
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
SOURCE: how do you replace jets on dream maker spa X-500
There is a tool that comes with the spa, instructions are in the owners manual. If you don't have the manual you can download it here
http://www.dreammakerspas.com/_PDFs/0607l.pdf
If you don't have the tool you can order one from Dream Maker.
SOURCE: my dream maker spa does not work. there is
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
SOURCE: Easy spa round - dream maker - overheat sensor is
Assuming that you've got adequate water flow, clean/new filter and the pump works as it should; Try a new sensor. They can and do sometimes fail and the sensor is much cheaper than the PCB. ;)
Cheers,
Ian, from: http://hottub.synthasite.com
SOURCE: I have a Dream Maker x-spa Dition 4 person spa. i
hi i am having the same problem have you managed to fix it and how any help would be much appreciated thanks joe [email protected]
