Corel WordPerfect Office 12 Home Edition (WP12ENGPCHE) for PC Logo
Posted on Apr 14, 2009
Unwanted headers/footers I recently finished a lengthy document; 15 pages to be exact, and decided to finish editing at a later date--here's the problem: every time I open the document, somehow there are all kinds of footers/headers added that break each line in the document into a new page. Help!!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
206
Points
I've never had this problem, but if you hit "Alt-F#," you'll get "Reveal Codes" at the bottom of your screen. Then go to the first page of the document where the problem begins, locate the code for the footers and headers you don't want, and then delete those codes.
Another, probably simpler approach is to click "Insert" and on the drop down menu, click "Header/Footer." Then unselect whatever is dotted. That should get rid of the headers and footers. JS
  • Anonymous Apr 14, 2009
    That should have read, "Alt-F3" for reveal codes, not Alt-F#. Sorry. JS
1helpful
Remove header footer
In both MS Word and Excel you go to the View Menu and select Header and Footer. It is simple to Delete any unwanted text from them.
In Word, In print layout view, you can quickly switch between the header or footer and the document text. Just double-click the dimmed header or footer or the dimmed document text.
To view a header or footer, switch to print layout view. To edit or format a header or footer, you need to display the header or footer you want.
How do I remove header and footer workspace from Word 2007?
1. Go to the page where you have the header/footer problem in your document
2. On the "View" tab of Word, click "Print Layout" (if not that view already)
3. Press the "Insert" tab
4. You should see an option that says "Header" and one that says "Footer" with a drop-down menu. For each, choose "Remove Header" or "Remove Footer" on the drop-down menu.
5. Repeat steps on other pages
See http://www.dummies.com/how-to/content/how-to-remove-a-word-2007-document-header-or-foote.html for more info.
How to create book type header in docx file means double header, one for tile which must be apply for whole doc. while other tiltle may change after few nuber of pages
this will set the head on every page till you remove it.
On the View menu, click Header and Footer to open the header or footer (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.) area on a page.
  1. To create a header, enter text or graphics in the header area.
  2. To create a footer, click Switch Between Header and Footer on the Header and Footer toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.) to move to the footer area, and then enter text or graphics.
  3. If necessary, format text by using buttons on the Formatting toolbar.
  4. When you finish, click Close on the Header and Footer toolbar.
I loaded MS Office 2003 on a new laptop running Windows 7, only to find that Word opens as a blank page with no toolbars, rulers etc - only the writing area. Excell works ok
The Word 2003 Window When Word is first started, a new blank page titled Document1 is opened automatically. This is a fresh page where you can begin typing a new document.
  • At the top of the window is a row of menus, including File, Edit and View.
  • Below that row of menus is a row of buttons for various tools (collectively called the "toolbars") to use in creating and editing your document.
Layouts in Word 2003
Normal - Normal is the default Word 2003 view. It shows just the text that you are working on, without margins or header and footer information. It doesn't differentiate between different pages of text.
Web Layout - The Web Layout displays the document as if it were a web page
Print Layout - The Print Layout shows the entire page you are working on, including margins, header and footer information. It shows the layout of the text on the page the way it would be displayed if printed.
I'm having issues with editing the header, I want it to say running head and title on the first page and then only the title and number following pages. I want MO 2003 back! donna
If you already have multiple pages in the document, go to your header. Click into it like you're going to edit it. This should open up the Header & Footer Tools tab on the ribbon (ie the giant menu bar at the top). Click on this.
On the Header & Footer Tools tab, 4 groups over from the right is a group called "Options." Make sure that the "Different on First Page" option is checked.
If you set up your header before you check this box, the first page header will delete itself. No need to panic, just copy it from the second page and then set up the second page header to your liking.
Word 2007 has inserted unwanted line across page of a text document. I can't select and delete line. How do I get rid of it? nickdb
It is probably the header that needs editing. You can edit the header by simply double clicking on the text or right click and edit header. To delete header go to: Insert, header icon and delete header at bottom.
Hope this helps!
1helpful
How to create headletter using openoffice 3.1
  • To add a header to a page, choose Insert - Header, and then select the page style for the current page from the submenu.
  • To add a footer to a page, choose Insert - Footer, and then select the page style for the current page from the submenu.
note.png The page style for the current page is displayed in the Status Bar.
  • You can also choose Format - Page, click the Header or Footer tab, and then select Header on or Footer on. Clear the Same content left/right check box if you want to define different headers and footers for even and odd pages.
  • To use different headers or footers in your document, you must add them to different Page Styles, and then apply the styles to the pages where you want the headers or footer to appear.
You type inot the headere space the text you want to seeEG
DR J JONES MBBS FCAS (logo)
address or other information
You can add a smal,picture or logo the exit HEADER and back tpo the main body of the docuement for your Dear Sir/Madam etc.
All this information is in the HELP file of OO
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Top Corel Computers & Internet Experts
k24674
Kolbrun...
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
