Radio Communications Logo
A
Anonymous Posted on Sep 07, 2013
Broken rubber antenna on Motorola talkabout 250
eradiostore
Level 3:
  • Motorola Master 1,672 Answers
  • Posted on Dec 17, 2015
eradiostore
Motorola Master
Level 3:
Answers
1672
Questions
0
Helped
796337
Points
4248
Parts are not available for this model. Your best options are to replace the unit or watch for a parts radio on ebay
1 Related Answer
Anonymous
  • Posted on Oct 20, 2012
SOURCE: Antenna for a Motorola Talkabout 250
Get a plastic tube (3/8 PVC will work) and use it as a mould. Pump it full of black RTV silicone. Fixed!
2answers
I have two older Motorola Walkies Talkabout FR60 wont send or receive and a T5820 with the rubber broken off the antenna is is cost feasible to fix or not
I believe for the FR60 walkie-talkies, if they are not sending or receiving, the issue could be related to the antenna, battery, or internal components. You can try replacing the batteries and/or antennas to see if that resolves the issue.
As for the T5820 walkie-talkie, if the rubber on the antenna is broken, it's likely that the antenna itself is also damaged. In this case, you can try replacing the antenna with a new one. Antennas are typically available for purchase online or at electronics stores.
In terms of cost, repairing older walkie-talkies like these may not always be cost-effective. If the repairs are extensive or require replacement of major components, it may be more practical to purchase new walkie-talkies instead.
Below are options of the options of walkie-talkies you can buy;
ir?t=emerald014-20&language=en_us&l=li2&o=1&a=b071kjlcjv
Is there any way to repair/replace broken antenna?
it you can get the part
it should be a matter of getting the back of and fitting it in
How to replace damaged antenna on the MR355R HT radio?
A replacement antenna is not available from Motorola for this model. The MR355R has a fixed antenna, and was not made to be removable. This being said, it is possible you could find a for parts only radio on ebay and disassemble it to remove the antenna for yours. Parts and schematics were never made available for the TalkAbout line of radios other than the TalkAbout Distance and Distance DPS.
Best regards.
How can I replace batteries in motorola talkabout 250
See thoroughly your Radio and you will get the place from where you can replace the batteries or you send me pic of your radio.
Motorola talkabout fr 50 antennas are broken down how can I supply the antennas
Sorry, parts were not offered for this style radio. However, you might watch for used ones on ebay for replacement parts.
Best regards.
Broken antenna. Is it possible to reconnect the copper wire?? talkabout 250
Sorry,but no. The radio is non-repairable once the antenna has been removed.
Best regards.
4helpful
Rubber antenna has become old and cracked and fell off almost both of my 250's exposing the coil wire antenna underneath. How to repair or buy another?
Many operators just wrap the coil with electrical tape. The antennas are considered to be non-replaceable, so they are not offered as repair parts. And if they were offered, they would probably cost more than new radios would.
Bill B
2helpful
2answers
On/off
The orange button on the right, below the antenna, is the on/off
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
