Does old Zenith Allegro Console Stereo - 8 track/AM/FM/turntable, have a belt drive phono? I can see metal gears to drive the stuck turntable .
The manufacturers of such items would usually buy in such hardware as record turntables from fairly standard catalogues.
One popular brand of turntable was the BSR but the design of other brands were similar. The metal gears aren't for driving the turntable but to drive the multichange mechanism so when one record has finished playing another will drop from the stack loaded onto the extended centre spindle.
This type of turntable is driven by a synchronous motor with a multidiameter spindle via a moveable idler wheel equipped with a soft rubber tyre. Lack of maintenance causes many problems and as the rubber tyre ages it tends to harden and lose traction on the inside of the steel turntable so when the record reaches the end and the metal gears engage there is insufficient torque and everything stops.
It is for that reason many older examples have had the multichange removed or disabled.
Removing the turntable centre motif should reveal a circlip which when removed will allow the turntable to be removed for maintenance.
