Expert
- Posted on Apr 14, 2009
Re: We have a slow leak coming from beneath the pool (the...
There is a way to locate leaks that are under water using a red dye that should be available at any pool supply store. It should come with directions, but basically you put the dye in the water and it will flow twards the leak and then you know where the crack/hole/leak is located.
