Kenmore 45981 Washer Logo
Posted on Apr 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HE4T will not enter diagnostic mode
I press drain and no spin but when I press a key under the options menu, the washer beeps twice (each time I press the key). I never get the c00 code to engage the latch and begin diagnostic run.
  • 9 more comments
  • lovells738 Apr 20, 2009
    I changed out the CCU and the Door Latch. Now, when I select a cycle, it just lights up as if it was going to run, but when I hit start, nothing happens. I had figured that to enter the diagnostic mode would cause the machine to recognize the new board.
    I have ordered another CCU just in case the one I received was faulty. I should have it in a few days.
    I am wondering if I have a wire harness issue. I am very close to replacing that as well.
    The MCU.....is that on the side of the motor? I have not checked the Ohm reading on that portion yet. I see 4 wires going into it from the back (removed the back panel). 2 single red wires and a connector with 2 wires together. Is this the MCU or do I need to look elsewhere?
    I am going to beat this challenge by god......
  • lovells738 Apr 22, 2009
    I tried the diagnostic thing again.....nothing. Hit "drain", hit "no spin" this is where the washer reads 02....2 minutes remaining. then I press the first option button and the machine beeps 3 times, but I press and hold for 4 seconds none the less, and I do this 4, 5, 6 times and still does not enter "c00" mode. Something is messed up. Could I have compromised the wire harness causing this problem?
  • lovells738 Apr 23, 2009
    Will DO! Got the sheet out this am but did not have time before coming to the office...will try it out tonight!
    Thanks for your patience.......
    The washer does not do anything. If I press a wash cycle or anything else, it lights up appropriately. When I press start, nothing happens....no clicking no clacking, no filling. I am at work now, but as I recall, it does not even beep. The only beeping I get is from trying to enter the diagnostic mode.
    Here are some pictures of the CCU
  • lovells738 Apr 24, 2009
    I still have the old door lock and will swap it with the new one to see if that makes a difference.
    OK, So I swapped out the old latch with the new one and nothing changed with the old one in place.
    But....when I hit drain, the light blinks. Then I hit no spin and the display changes from 12 min to 02 min. If I hit an option button for 4 seconds 4 times nothing happens except beeping 3 times, BUT, if I hit drain and then no spin, and then press start, I hear a relay click 2 times......this is the only action on the front panel that I can do to get sound of any sort from the CCU.
    I hope to have the new CCU today so I can replace or at least rule out the CCU as the potential cause.
  • Anonymous May 11, 2010
    try pressing any button except cancel or start. you need to press and hold 4 seconds on off 4 times or untill all the light light upi and say 88 try this.let me know.
    or you are still not doing it right. you need to select drain go to no spin then press a key under options but you have to press, press, press with no pauses unt6ill c00 shows up.
    I am just wondering why do you need to get into diagnostics?
    is there a problem?
  • MaddMat Jul 12, 2017
    Get some silver solder and a soldering iron and resolder your mother board contact points these machines all have issues with this and a new board is often as bad. I baught new latch, and other parts, but the machine was not totally fixed and error free until I took it apart and resoldered it. It is NOT difficult to do, but get a pair of magnifying glasses
Anonymous
Level 3:
  • Master 530 Answers
  • Posted on Apr 22, 2009
Anonymous
Master
Level 3:
Answers
530
Questions
Helped
185705
Points
1609
Usually if it's you motor controller it should stil go into diagnostic mode. so that is probably not your problem. can you post a picture of the inside ccu board and of the door lock this would be helpful.
  • 8 more comments
  • Anonymous Apr 23, 2009
    did you find the tech sheet at in the bottom panel? but the answer to your question is YES if you did not wire it right it won't lock the door because it doesn't recognize that it it there and it won't go into diagnostics if the door is not connected right. check the door switch again and get that tech sheet out
    check the door circuit first. make sure the door switch is not broken. there should be a button that you can press in and out at the very top. make sure that is not broken.
    oh...just to answer your other question about the motor the 2 red wires going to your motor is actually a tachohmeter that is inside of your motor. the motor and everything attached to the motor is one unit. the mcu is a computer board mounted to the bottom of the cabinet. But don't worry about these things these are a seperate thing if your mcu wasn't working it would give you a f28 error code i believe.
    I just want to know when you press start what does the washer do? do you hear the door lock locking or is it completly dead? does it lock and you hear a humming sound? did you turn the hoses off. make sure the fill hoses are turned on. is there any other error codes that you have seen?
  • Anonymous Apr 24, 2009
    i think if i recall right the green wire is in the wrong place switch the one next to it. i believe it should be from right to left...white green black white. try that and let me know
    please rate me so i can track you better
    i am sorry i think that is correct. i don't know if this is comeing out ok but this is a pin config off a good one. so yours is right. I still need a picture of your door lock assembly please. inside and out
    i am pretty sure it has to do with your door lock
  • Anonymous Apr 25, 2009
    yes i hope you get your new ccu board soon too. so you hit drain/spin, no spin, options extra rinse? 4 times? When will you get your new ccu board? clicking sounds are good. usually when you have a bad ccu board and it gives you a fdl/f11 error you will hear that clicking before it fails. I thought they solved that problem along time ago. They made all these ccu boards with loose solder conections in them. causeing f11/fdl error codes. the only thing you can do is check and ee if there is voltage comeing out of the board to the door lock and if there is no voltage comeing out of the board YOU HAVE A BAD CCU! if you are getting voltage to the door lock then you have a bad door lock. Anyway let me know when you get the new board and if this solves your problem all you can do now is wait.
    you are correct, but all the CCUs are bad just a poor solder joint job. BEST TO RESOLDER YOUR CCU CONTACTS, All of them and your machine will work perfect
    it is NOT hard to do, and youll be happy and save much. I have a brand new board I didn't use and never returned
MaddMat
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 06, 2009
MaddMat
Contributor
Level 1:
Answers
Questions
Helped
1024
Points
PLEASE HELP!!!!!!!!!!!!
MY He4t Kenmore. I have now purchased three (3) new CCUs and non have functioned. All I get are three dashed red lines with no response.
Matt
How to run diagnostic on Kenmore elite smartwash quiet pak 9 HE4t washer? Model#110.45087401
Diagnostic mode for Kenmore Elite He3t model 110 42926 ...
iFixit https://www.ifixit.com > Answers > View > Diagnostic...
Apr 8, 2016 - With the washer empty, close the door. · Push "control/on" or "Start" · Select "Drain/Spin" · Select "No Spin" by pressing SPIN SPEED touchpad.
3 answers · 2 votes: I believe this is very similar to the model I have. Here is what I did to run a diagnostic. ...
F11 error code during Diagnostic test? - Kenmore ...
1 answer
Jan 18, 2016
SOLVED: F11 code error on Kenmore HE3 - iFixit
Mar 3, 2011
SOLVED: f h error code - Kenmore Elite HE3 ...
Feb 21, 2012
It seems like the washer has no power - Kenmore Elite ...
Nov 2, 2017
More results from www.ifixit.com
Diagnostic Test; Starting The Test Mode; Test Program ...
ManualsLib https://www.manualslib.com > ... > User manual
Close the door. Select the DRAIN/SPIN cycle. Select NO SPIN by pressing the SPIN SELECT button five (5) times. Push Prewash Option button four (4)times within ...
2answers
Control locked
Press the end of cycle signal- button for 3 seconds and it should work..
1helpful
Washer won't drain
DIAGNOSTIC MODE
To enter diagnostic mode follow the steps below.
1. Turn the power on at the power point but off at the machine.
2. Press and hold WASH TEMPERATURE SETTING DOWN and then press POWER until the
machine gives 2 short beeps and lights up.
3. Release the buttons after the beeps as the beeps indicate diagnostic mode has been entered.
4.1 Last Fault Data
When in diagnostic mode the last fault can be found by pressing the SPIN SPEED UP or DOWN
buttons until the HOLD and SLOW lights are illuminated. Binary can then be read from the wash
progress lights.
4.2 Drain Pump Test
MW Washer
When in diagnostic mode press SMART TOUCH CYCLES to activate the drain pump. To
deactivate the pump, press SMART TOUCH CYCLES again.
GW Washer
When in diagnostic mode press REGULAR to activate the drain pump. To deactivate the pump,
press REGULAR again.
4.3 Water Valve Test
The water valves can be activated in diagnostic mode by pushing WASH TEMPERATURE SETTING UP to activate the Hot Valve and WASH TEMPERATURE SETTING DOWN to activate
the Cold valve as with previous models.
Pressing each button once will activate the valve. To de-activate valve press the same button
again. This is also good to use when installing machines as it takes the shock out of the fittings
and seals and allows checking for leaks on the inlet hoses, both machine end and tap or super-tub
end.
Caution: Do not leave the machine unattended when either or both valves are operating
4helpful
4answers
I can not get it into service mode.
There is not a "diagnostic mode" for the neptune washer.
All tests and functionality are done at each setting using the timer (except the tach circuit)
What is the problem you are looking to diagnose??
Thanks!
2answers
Won't spin
Close the door firmly and make sure the machine is turned on. Press and hold the Chime and Extra Rinse keys until the control beeps to enter Service Mode. All indicator lights will turn off except the "Door Lock' indicator signifying the door is locked.
Press the Rinse & Spin key then rotate the cycle selector knob in either direction to display the most recent error codes if there's any. Press and hold the cycle selector to display the number of cycles since the error occurred. List down at least five most recent codes and post it here for us to determine what the problem could be. Press and hold the Delay and Chime keys for three seconds to clear the list. Press the Rinse & Spin key again to exit diagnostic codes list.
Press the Spin Only key while in the Service Mode to begin the Board Input Test. Set the rotary cycle selector to Super Wash then press it to display the position of the door switch. "OP" will be displayed if the door switch is open or "CL" if it is close. Replace the door lock/switch assembly (part #34001265) when "OP" is displayed even the door is close. Press the Spin Only key again to exit the Board Input Test.
Press the Spin Speed key while in the Service Mode to begin the Board Output Test. If water is present in the tub, set the rotary cycle selector to Quick Wash then press it to turn on the drain pump and drain the water. Press the rotary cycle selector again when the water is fully drained to turn off the drain pump.
Press the Delay button to turn on the motor and the Delay indicator light. The machine should tumble clockwise then counterclockwise with 5 second durations each and 2 second intervals. Press the Spin Speed key again to exit the Board Output Test.
Press Off or press and hold Chime and Extra Rinse keys for three seconds to exit Service Mode. Unplugging the washer will also exit Service Mode.
Perform the tests above and let us know the results for us to determine the cause of the problem or the necessary action to undertake and give you the specific and detailed instructions on how to fix it.
8helpful
2answers
Kenmore Elite Calypso Washer fills then doesn't advance..
You can get a replacement pump at pcappliancerepair.com - part # 285990 - and a lifetime replacement warranty on the pump - for (at this time, July 2009) about $124 total.
However, before you do anything you can run the washer diagnostics by pressing the following key sequence to put the washer into the Automatic Service Diagnostic mode (make sure the washer is EMPTY of clothing when you do this):
Prewash Options --> Wash time --> Prewash Options --> Wash Time (also known as a "Key Dance"). You have to press the 4 keys within 5 seconds for the washer to enter the diagnostic mode.
The washer will start counting down from 99 on the LED display and will run through the following steps:
Display 99-81, Nutate & Fill (washer plate rocking motion is called Nutate), Cold Water, Drive Motor Speed 300
Display 80-61, Nutate & Recirculate, Cold Water, Fabric Softener Dispenser, Pump in Recirculate mode (wash), Drive Motor Speed 275
Display 60-41, Nutate, Fill & Drain, Hot and Cold water, Bleach Dispenser, Pump in Drain Mode - LISTEN FOR IT TO RUN, Drive Motor Speed 250
Display 40-21, Nutate, Fill & Drain, Hot Water, Detergent Dispenser, Pump in Drain Mode, Drive Motor Speed 225
Display 20-01, Spin & Drain, no water fill, no dispenser solenoids, Pump in Drain Mode, Drive Motor Spin Speed 500
Return to Standby at the end of the countdown.
You can press Cancel at any time.
Also, if you can get the washer drained, when you tip it on its side and open the bottom cover (unplug the AC power first and secure the water lines & drain), if you shine a bright flashlight up inside the outer case of the washer, look for a plastic sleeve with some paperwork in it.
If it is there, you will find the washer's Service Diagnostic Paperwork, a large fold-out sheet that shows all the keystrokes, like those documented above, for putting the washer through a bunch of diagnostics.
Whirlpool WFW9600T Washer - How do I run diagnostic mode?
Actually, on my particular whirlpool steam duet model, I had to press the deep clean button four times to make it go into diagnostic mode.
1helpful
Hi I have a whirlpool duet front load washer (GHW9100lW1) and the status is stuck on CONTROL LOCKED and i can't change it and the machine is no longer working.
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
■ Close the door.
■ Push CONTROL/ON (if present on this model).
■ Select the DRAIN/SPIN cycle.
■ Select NO SPIN by pressing the SPIN SPEED touch-pad.
■ Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
3helpful
2answers
Door stuck Locked Control Locked light on
Try unplugging the washer for at 30 minutes to reset the computer, first. If this proves unsuccessful, you can retrieve you clothes by using the manual release. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Once you retrieve your clothes, try running diagnostics on it. You can envoke the diagnostic sequence by selecting DRAIN/SPIN, NO/SPIN and then pressing any button under OPTIONS 4 times (must be the same button). The display should go to "C00" as the washer begins a sequence of tests that checks the fill functions, door lock, dispenser functions, motor speed, spin and drain. Allow the washer to run through the entire sequence and shut off. If anything is wrong an error code should be generated. Hopefully, all you had was a minor glitch. Let me know how things turn out. I hope this helps you.
2answers
HE3 front load washer
PS you can also place the washer in diagnostics mode to see if the same "F05" error is displayed. To do so, select DRAIN/SPIN, NO SPIN and press any key under OPTIONS 4 times (it must be the SAME key, though). "C:00" will be displayed as the washer runs through a series of tests that check the door latch, flow meter, hot and cold water inlets, dispenser, motor actions, drain pump, AND the heater & NTC. The heater and NTC are checked at segment C:05. The washer should advance through all segments and end after C:08. There is a tech sheet inside your washer along one of the side panels that has all this information available to you.
Alexander
vince
