Question about Samsung LN Televison & Video
I have a 27 inch Samsung LCD and can't get HD or even a connection. I'm using a 3 prong cable for my HD not a plug in...so not sure where to plug them in the back...colors are misleading me I guess. My other Samsung shows HDMI2/DVI but that's with a cable and the only option. The one in question show Pc....?? THanks
6ya staff
SOURCE:
Benimur
Louie Role
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
Anonymous
SOURCE: Connecting an LCD TV to a computer to use as TV and Comp. Monitor.
Im no expert on the subject, but I use my L37 for a monitor, and use just the vga adapter. It works good as a monitor, and both dvds and my hdtv wonder tuner card look great through the vga connection. They do make adapters for dvi to hdmi. Although, hdmi also carries sound, but you wont get that out of your dvi output from your card. So you might not have sound when using that connection, as your tv may not look to the headphone type jack used for sound imput from your computer when you select the hdmi source on it. If you have speakers already connected to your computer you may not care. Also if you have a 720 p Vizio, 1366x768 is the highest resolution you are going to get out of it anyway, if I'm not mistaken. I'm Not sure why you would need 2 connectios to the same monitor either. I posted 1 link below because they had several dvi to hdmi adapters. Hope that helps.
http://www.bizrate.com/computercables_adapters/products__keyword--hdmi+dvi+d+dual+link.html
Posted on Aug 01, 2008
Anonymous
  • 98 Answers
SOURCE: My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Posted on Feb 06, 2009
Anonymous
SOURCE: samsung 610 46'' lcd - hdmi input not working
why hdmi input wont show up
Posted on Dec 22, 2009
madiga2001
  • 10 Answers
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
Posted on May 11, 2010
Im trying to connect my playstation 3 to my 42 inch LG lcd tv
When connecting the ps3 to a nice TV like that, you want to use an HDMI cable. You can use the stock red white and yellow plugs to connect to the back of the TV, however you will not get the full HD experience like with the HDMI cable.
Dec 25, 2010 | LG Televison & Video
How can I connect my mackie mixer 1202-vlz3 to my mac mini
use the xlr (3 prong) main left and right outputs of the board. get xlr to 1/4 inch cables. one end will be 3 prong, to plug into the mixer, then the other end will be a mono 1/4 inch plug, like a big headphone plug. Then you have to get a dual mono 1/4 inch to stereo 1/8 inch adapter and plug it noto the line in. if there is no lone in, but a microphone jack instead, you will get a mono signal instead of a stereo signal. in this case, just use 1 channel of the mixer, instead of both of the stereo outs, and use a single mono 1/4 inch to mono 1/8 inch adapter.
the xlr to 1/4 inch cables can be purchased at a music store. the 1/4 inch to 1/8 inch adapters will probably need to be purchased at radio shack.
Nov 03, 2010 | Mackie 1202vlz3 12 Channel Mixer
I cant get any picture on my sony tv when i connect my ps3 upto it, yet get a picture instantly on a cheap 26 inch hd tv. i'm using a hdmi cable on both
Silly question -- but are you sure your Sony TV is on the correct HDMI channel? My 32 inch LCD has HDMI1, HDMI2, HDMI3. You must make sure you plug the PS3 into the correct HDMI channel and make sure you're tuned into the same one.
Aug 03, 2010 | Sony Playstation 3 (PS3) Console
Thin green line
Most likely your tv has a defective LCD panel. If it's in warranty, drop it to the warranty depot shop to repair.
Jan 18, 2008 | Televison & Video
TV not finding Digital Channels from Cable Box
I don't know where you're located but you may want to double check with Time Warner on the availibilty of an HD box. I have TWC with an HD tier package and have an HDMI out on the box that runs directly into HDMI on this TV. Hope that helps!
Jan 17, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Connecting Laptop to LCD
It might have something to do with wether the VGA cable has all pins connected.
I think some cables don't have all 15-pins wired.
As soon my LCD TV works I will post the outcome.
Greetz Arno
Nov 07, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Ilo 27 inch hdmi/dvi hd tv monitor
Jul 31, 2007 | iLO V27DMBX Television
Televison & Video Logo
55 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
