Tomtom GO 300 GPS Receiver Logo
Posted on Sep 12, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tom tom 300
Hi My tom tom wonts switch on. I have reset it and still it comes on with a boom boom noise and shows the 2 hands on the screen. It also shows the loading bar at the bottom, but then it just freezes and nothing happens. can anyone help please ASAP
  • 1 more comment
  • Anonymous Nov 11, 2007
    Have the same problem tried the tomtom home software updates. still in coma!
  • dave2lissy Nov 13, 2007
    i have the exact same problem HELP
  • secrets1 Jan 15, 2008
    i have the exact same problem as nicola
Anonymous
Level 2:
  • Expert 174 Answers
  • Posted on Jan 16, 2008
Anonymous
Expert
Level 2:
Answers
174
Questions
Helped
132464
Points
277
"My tom tom wonts switch on. I have reset it and still it comes on with a boom boom noise and shows the 2 hands on the screen. It also shows the loading bar at the bottom, but then it just freezes and nothing happens. can anyone help please ASAP"
Sound as though your Map data card is corrupt. Remove the SD card and check it with your computer using a card reader. Backup the SD card onto your computer. You can run either chkdsk or go to the drive letter under 'My Computer' right click and select properties, then tools, then check now. You can also try starting the Tomtom with the SD card out of the unit. It should show a picture of the Tomtom with a 'X'. You can also try copying the data on the SD card to another SD card.
A
Anonymous
Try a software update with tomtom home connect your usb cable, if pc doesn't recognise your tomtom, reset the tomtom while still connected to the pc. works most of the times...
My Tom Tom 530 switches on ok but screen shows no signal, when outside. I have pressed the reset button problem still persists. Can you help! Thanks.
Tap the map screen in the lower right hand side where the bars are then tap the screen on the upper right hand side where the battery is. This will bring you to the satellite screen. Leave it alone for about a minute if you don't see any grey bars showing on the bottom of the screen your unit has a problem. If you do see grey bars at the bottom leave it alone and let it do it's thing. Sometimes for the first time after not using it for awhile it may take up to a 1/2 hour for it to locate the satellite's
May 08, 2009 • GPS
Tom tom go 300 wont turn on
c48ee42.jpg ctf1800
Rank:guru_s.gif Guru
Rating: 85%, 3949 votes
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
Tom tom 300 sat nav
Go to the preferences section and you will see apromot that shows you how to fix that!
Jazzman02
3answers
Tom tom seems stuck on opening screen
IT WONT DO ANYTHING PASS THE SIGN WITH 2 HANDS
Tom Tom 1 Wont Switch On
Well, dont know if you already have tried, but do a reset:
http://www.tomtom.com/support/index.php?Language=1&query=reset&FID=6965
Please follow instructions.
(Please remember to rate, thanks...)
1helpful
2answers
Tom tom 300
If the unit is still under warranty, send it back to Tomtom. Even if the unit is no longer under warranty, complain to Tomtom. There is a problem with the CLA (cigarette lighter adapter). It can cause internal damages to your Tomtom. What happens is that there are three wires in the CLA along with a voltage stepdown circuit board. The wire are +, -, and a signal wire. If the signal wire get disconnect the voltage could spike up to 12vdc. The unit is designed for only 5vdc.
If the unit is out of warranty then try the following website for repairs. They can fix the two chips which usually blows.
http://www.satnav-shop.com/
Tom tom
that sounds like there is something stuck in the edges of the touchscreen...
try & run a toothbrush or your finger nail or a piece of paper flat against the screen & run it 360 around the edges of the screen...
Failing that buy another faulty one with different issues from an auction site & chop & change the faulty parts.
as you are out of warranty it wont matter.
13helpful
6answers
Tom tom go 500 wont power up
Press the power button for 15 seconds and your tomtom will turn on with the drum sounds yor tomtom will now reset but nothing will be deleted off it and it will now hope fully work.
Bye
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
