Do you have combination switch outlet?
Copy following link:
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
Add comment with more information as needed.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Installing a Leviton 5225 switch with outlet.
A switch is wired using the hot wires only, the black wire. It is simply a break in the line so that when the switch is off no power flows and when the switch is on the power does flow.
You are correct that the middle outlet would have two black wires and two white wires.
If you want to tap into that middle outlet and run power up the wall I suggest you look into some wiremold products. Go to their website, or any home depot and check it out. Get back if you think I can help you further. I am an electrician.
Here is a link that may help you.
http://www.make-my-own-house.com/electrical-wiring-diagrams.html
SOURCE: wiring switch and GFCI outlet tandem, so that
There should be 2 screws at the top that say LINE. This is where you connect the power wires. The 2 screws at the bottom should say LOAD. That is where you connect the second outlet.
SOURCE: I can't seem to get my T5225 combo outlet to work.
Electricians don't guess, they test.
Remove device.
Separate wires for testing.
Use ordinary 2-prong tester.
Tape wood sticks to tester leads to keep hands away from power.
Turn on power.
Test each wire to bare ground wire.
Tester will light up on Hot wire. This wire connects to dark-colored screw.
Hot is identified.
Now test Hot wire to each other wire in box, including white wires in back of box (exclude bare ground wire)
Tester will light up on Neutral wire. Neutral wire connects to silver screw. This will complete circuit to receptacle part of device.
The last wire goes to Load (light). This wire connects to brass-colored screw, and will complete circuit to light..
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps shown above for a price.
SOURCE: We are trying to install
You are installing a combo device with switch and outlet.
The outlet is tamper resistant so a child cannot stick a key into outlet and get shocked.
For the outlet to work, a 2-prong plug must be inserted.
Wiring the device:
Device has different colored screws: dark, silver and brass.
Do not unwind wires that are twisted together.
White wires that are twisted together and located in back of box are included in testing.
Use ordinary 2-lead tester.
Tape tester leads to wood sticks to keep hands away from power.
Turn power ON.
Tester lights up on Hot wire. This wire connects to dark screw.
Hot is identified.
Test Hot wire to all other wires, except bare ground wire.
Tester lights up on Neutral wire. Neutral connects to silver screw.
If you do not have a Neutral wire, then outlet will not work for that location.
You can get the outlet to work by connecting bare ground to silver screw, but that is violation of code.
Last wire goes to Load (light, fan, motor).
Load wire connects to brass screw.
In your case, this is red wire.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on switch or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: can't get my switch to
Turn off the power to the receptacle that will be replaced by switching off the circuit breaker in the fuse box. Check that the battery is good in a circuit tester. If not, replace the battery. Place the tester's two ends in one set of the receptacle's slots, then the other set. The light on the tester should not come on. If it does, the correct circuit breaker has not been switched off. Take off the receptacle's face plate by first removing its screw. Detach the two screw securing the receptacle to the box and pull out the receptacle. Loosen the receptacle's terminal screws and pull away all wires from the back of the receptacle. Take out the receptacle (if working properly, it can be reused). If the ends of the wires are chewed up after removing them from the existing receptacle, cut them off with wire cutters. Strip off 1/2 an inch of insulation from the ends, using wire strippers. Bend them into loops with the pliers. Bend the copper ends of all wires into a loop, using a pliers. Connect the white wires to the silver terminal and tighten the screw to the wires. Connect the black wires to the gold terminal and tighten the screw to the wires. Connect the bare ground wires to the ground terminal and tighten the screw to the wires. Push all cables into the back of the box, followed by the receptacle. Attach the receptacle to the box with the two screws. Hold the new faceplate in position and install the screw. Turn on the power at the circuit breaker.
Testimonial: "Thank you your info was great!"
