I have an Akai S5000 with USN controller on board which worked fine with Win XP Pro 32 bit. I now have Win 7 64 bit and the driver is incompatible. Anyone know of / got a Win 7 64 bit driver? No sign of anyting on the Akai site as the S5000 is well discontinued now - but stilla great device.
Sorry - bit of typo here- it should read USB controller (an oprional add-on card for PC control of the S5000) rather than USN. PeteSorry - bit of typo here- it should read USB controller (an oprional add-on card for PC control of the S5000) rather than USN. Pete
You can't post conmments that contain an email address.
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: http://www.turtlebeach.com/support/files/241/ . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
Find out what type of Nvidia graphics card it is, then goto the nvidia site and download the installer from them. The installer usually supports multiple families/models of cards. But yes, you need to download the installer for Win XP pro. You can do it manually, or have it automatically scan for the hardware and download the correct driver automatically.
Here's a link to the automatic --> http://www.nvidia.com/Download/Scan.aspx?lang=en-us
Intel Desktop Board D945GCNL HD Audio Controller 5605 Windows Vista(32/64)/XP(32/64)/2000
Installs the Realtek audio driver version 5605 for Intel® Desktop Boards.
IMPORTANT: Audio drivers may fail to install in Windows* XP 64-Bit Edition. Symptoms may include error messages, such as "Error in installation" or "Unknown error". Microsoft's Update for Windows XP x64 Edition (KB901105) fixes this issue. After installing this update, the audio drivers for Windows XP 64-Bit Edition will successfully install.
i got digi 001 running on windows 7...
i left my xp on hard disk while installing win 7. it kept xp on folder windows.old folder. in control panel i saw digi as multimedia adapter wich system couldn't recognice. hit "change settings" -> driver -> update driver
used my old windows to search for driver. it found "Dalvin.sys" driver for adapter. installed that. after that windows recogniced digi 001.
downloaded "digidesign asio 6.11" driver installer for win-xp and ran it.
and bingo - it works!
in every step windows was complaining and asking do i want to do this. just yeah'd everything. as i just had a clean install of win 7 i just thought whatta heck i can install everything again if it would not work, but it did.
so in a nut shell:
1: install Dalvin.sys in control panel for digi 001
2: run digidesign asio 6.11 driver installer for win-xp
for me it worked but i absolutely take no responsibility if you mess your system with this! at least reaper got a sound out of it. i haven't tried to record anything yet. but asio settings seemed to work as they used to do in xp.
Well, we wont know until you try. In my opinion, your 32/64 bit issues will be solved, but you would still have the normal vista/xp compatibility issues.
But that is to be expected, like when we all upgraded from win98 to XP.
So - I would recommend downgrading to Vista 32 bit, or getting the 64bit software version of the programs you want to use.
Good Luck, and let me know what you did, and how it turned out! :)
