SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Run just the washer and see if breaker traips if it dose you will know it the washer part that is doing it check power wire on back to see if wire lose or washer motor is bad. But it it dont trip breaker start up only dryer and see if it trips the breaker and if it do still check power wire going in back of dryer and check element see if the element is lose and check motor if no wire is lose and grounging out.
