I too have a similar problem. When I press the display button on the back side of the camera, the view is shown. However one can not click the camera with the display button in pressed positionI too have a similar problem. When I press the display button on the back side of the camera, the view is shown. However one can not click the camera with the display button in pressed position
You can't post conmments that contain an email address.
CCD sensor faulty especially if you can play back pictures that were captured properly, but have a blank screen in capture mode. Replace sensor and camera will work fine.
The water has ruined the LCD, water and electronics seldom mix, you are lucky it still will at least take pictures. If it is a high end model then send it back to the Factory repair center listed in the user manual (or phone number to find a repair center).
From what I can understand, if the camera is sill able take pictures but is not displaying any thing on the LCD, then it is a problem with the LCD or LCD cable connecting to rest of the camera or LCD driver on main board.
It can be as simple as a loose flexible PCB connection to the camera main board. ' +
'' + google_ads[i].line1 + ' ' +
'' + google_ads[i].line2 + ' ' + google_ads[i].line3 + ' ' +
google_ads[i].visible_url + ' ';
var adsByGoogleRight = "-40px";
if(dartRecieved){
document.getElementById("ga_300x250").style.clear="both";
document.getElementById("ga_300x250").style.left = "0px";
document.getElementById("inner_adv_caption").style.display = "block";
adsByGoogleRight = "5px";
else if(isHealthinationExist){
var healthinationBox = $('healthonationBox');
if(healthinationBox){
var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight;
var ga_top =getObjXY(document.getElementById("ga_300x250"))[1];
if(ga_top-helthinationBot >0){
document.getElementById("ga_300x250").style.width = "530px";
else{
document.getElementById("ga_300x250").style.width = "410px";
$('boxAdWrapper').style.display = "none";
else{
//add "ads by google"
var logo_img = '';
s += '' + logo_img + '';
document.getElementById("ga_300x250").innerHTML = s;
var currl = $('related_links');
var currq = $('related_questions');
if(currl!=null && currq!=null){
var currltop = getObjXY(currl)[1];
if(currltop > rltop )
currq.style.clear="left";
return;
var niB = document.getElementById("niBannerID");
if(niB && niB.style.display=="block"){
document.getElementById("q_answer").style.marginTop = (niB.offsetHeight+70)+"px";
If camera shows Menu item or any on-screen display in LCD but no live view to take picture then it can be either aperture problem or defective ccd imager. And if you do not see any display icon in LCD then of course LCD section is bad or LCD back light is Off for some reason. Try to see faint image in LCD if it is totally blank by pointing good amount of light with flash light or some thing.
is it dark on picture playback (picture from before fault occurred) and menu also, if not then turn exposure value back up, on my camera you do this by pressing the WB (white balance/exposure button) and turning it to 0. it is the up button on the 4 way knob. but I have a Panasonic FZ20. yours may be different. If the whole LCD screen is dim, and the viewfinder is OK, then you have a problem with the LCD screen. You will need to take it to the repair agents.
When I take a picture, there will be know image. Black. I went into the "share" and the image is black. I kept my smart card and the other images are ok but the knew ones are black. Camera has power. I took the smart card off. Still the problem, black. Took the old images off and took some more shots. All black!! MMMMM?
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
It sounds like a bad connection on the ribbon cable of the LCD screen to the camera's motherboard. The fact that when you physically move the camera around and you can get the screen to then work, tells me something is loose inside.
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty.
I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
