Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor Logo
A
Anonymous Posted on Sep 04, 2013
Need a check valve for ac 2001b clarke air compressor
Replace check valve
Liam Mcnulty
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 33 Answers
  • Posted on Oct 16, 2014
Liam Mcnulty
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
33
Questions
0
Helped
9156
Points
34
In uk machine mart are distributers
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Apr 04, 2009
SOURCE: Clarke AC 2005A air compressor will not start under pressure.
It sounds like you have a bad check valve. Remove the main discharge line to the tank and listen for air. If you have any coming out your check valve is bad.
Anonymous
  • 3 Answers
  • Posted on Sep 12, 2009
SOURCE: Clarke model 2001, part fan 2001-13 air compressor
try
www.machinemart.co.uk
Anonymous
  • 1167 Answers
  • Posted on Sep 27, 2009
SOURCE: type of oil
here is a bottle for £10 a litre we can supply it for you buddy but just saves hassle buy from ebay instead http://cgi.ebay.co.uk/COMPRESSOR-OIL-1Lt-SUITABLE-FOR-DIRECT-OR-BELT-DRIVE_W0QQitemZ120471848230QQcmdZViewItemQQptZUK_Air_Tools_and_Compressors?hash=item1c0cae8526&_trksid=p3286.c0.m14
Anonymous
  • Posted on Dec 29, 2009
SOURCE: I need a drain plug for a Clarke Air pancake two
Most drain plugs are universal, check your local hardwarwe. That is where I found mine.
Testimonial: "Great idea, it didn't realize universals were available. Thanks"
Anonymous
  • Posted on Aug 06, 2010
SOURCE: I have a Clarke SHHH air 2/9 compressor
I also have a Clarke SHHH 2/9 with the same problem. I sent it off to machine mart service dept. in Nottingham who quoted £189 to replace a faulty pump. Am not going ahead with repair since replacement cost is only £250. Cost sending to Nottingham (from local machine mart) & cost of estimate & cost of return (to local machine mart) was £24 which I thought was reasonable. Very unimpressed with compressor itself wich failed after only light use.
WHERE CAN I FIND A CHECK VALVE FOR A CLARKE AIR COMPRESSOR 4 GALLON 2 H.P. MODEL AC 2001 B?
most non return valves ( check air valves ) are a generic product used on all compressors
try a compressor repair shop, on line to a compressor distributor that handle your make
if you take the faulty valve with you you may even get one from a good hard ware shop as the have spares like this on the self.
2answers
Where can I find a AC2003B-0045 check valve for a Clarke air compressor
it's most likely a pressure safety valve and it's EFFIN important !!!
Looking for parts for a Clarke air compressor
try machine mart in uk they are main agents for clarke machines over here
3helpful
2answers
Compressor runs but the air bleeds out think it might be stuck reed
If your compressor reaches the cut-out pressure (or very close) , most likely not reed valves. Usually air leaking when compressor is shut off is result of leaking check valve at the tank. Look for brass valve and remove. Somtimes the valve is repairable if debris is keeping valve open. Clean or replace as needed.
2answers
Hi
Can you hear any leakage, if not then I would suspect a valve is jammed open.
Gently tap valve housing with a soft hammer, may dislodge the valve.
3helpful
Top Clarke Air Tools & Compressors Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
