Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
Anonymous Posted on Apr 13, 2009
Bravia & Sky+HD, aspect problem
Hi folks, I've been a proud Bravia owner for about 15 months now. It's a KDL-40s3000, and I've hit a bit of a problem with it.
Recently upgraded from Sky digital to Sky+HD, which provides a HD picture over a hdmi cable to the TV. All HD shows aired by Sky are displayed in widescreen and look good, although I'm not certain I'm seeing the whole image. Non-HD shows are aired in channel/show specific aspect ratios, the TV doesnt auto-format, and I seem to be unable to manually adjust that. The result is a skewed image.
Is it that the Bravia doesnt support other formats through it's hdmi port? (In fact there are 2 hdmi ports on the TV and I run my PC through the other at 1280x768 res without problems)
I've checked the sky manual, there seems to be very little applicable info in it.
Has anyone else seen similar problems? Any advice appreciated, thanks.
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Jun 01, 2009
Anonymous
Contributor
Level 1:
Answers
20
Questions
0
Helped
11961
Points
34
There is nothing wrong with you Sony Bravia TV and it suppport all HD and SD formats.
Are you viewing the HD version of the channel when it is showing a standard defination show. e.g SKY1 HD instead of SKY1.
This means that regular standard defination shows are in a 4:3 ratio and does not fill the whole screen. In order to view these type of shows you will need to tune to regular channel instead of the HD version.
You can check if a show is brocast in HD by going into the tv guide and checking for the HD symbol in the programme symposis.
Example
I can't get my Sony kdl 40s3000 out of standby mode
You can look to see if power light blinks in a sequence which would be a error code but unless you are prepared to take it apart and know what to look for best left to a tech or a shop..
1helpful
Need a remote contol code for sony bravia kdl 37U4000 for skyplus HD remote control
Hello
Remote codes for Sony TV with Sky Plus remote are:
038
533
679
505
533 038 039 064 102 130 505
Ok.
2answers
On Sony Bravia KDL-S40A12U screen occasionally turns black for a couple of seconds. Only happens on the HDMI channel. Sound still works, but no picture?
Possibly source issue(Box/Satt). Some HD boxes do not have very good HDMI processors or the actual program source feed may be faulty. HD sources are still not 100% efficient
54helpful
3answers
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
2helpful
Sony KDL-40WL140 vs KDL-40Z4100
KDL40Z4100 Product Features
  • 16:9 Full HD 1080p Resolution (1920x1080p) LCD Panel
  • Motionflow 120Hz; improves TV & DVD viewing
  • DMeX compatible; allows seamless feature upgrades
  • DLNA® Compliant - view photos from another room
  • HDMI x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40Z4100/B
  • Display Technology: TFT active matrix
  • Display Size: 40 inches
  • Image Aspect Ratio: 16:9
  • is_hdtv_compatible: Y
  • speakers_included_description: 2 speakers
  • Height: 23.9 inches
  • Width: 37.2 inches
  • Depth: 2.8 inches
  • Weight: 39.7 pounds
  • Refresh Rate: 120
KDL-40WL140 Product Features
  • Motionflow™ 120Hz - clear, smooth motion for DVDs, TV
  • DMex ™ compatible; allows seamless feature upgrades
  • Enhanced XMB™ with 3D graphics incl. TV Guide
  • HDMI™ x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40W4100
  • Height: 25.4 inches
  • Width: 38.8 inches
  • Depth: 4.3 inches
  • Weight: 44.1 pounds
  • Refresh Rate: 120
Bottom line for the extra connectivity and DLNA certification i would go with the
Bravia Z-Series KDL-40Z4100/B 40-Inch 1080pBecause if you connect this to your in home network you can stream music videos and music off you PC onto your TV without the need for extra wired or memory cards etc.
Otherwise if you don't need this feature the other options are identical on the other TV so it is just as good a choice.
1helpful
Volume not working on sky remote
You will need a code in order for the tv functions of you sky remote e.g volume to work.
Click here to find out what remote control version you have.
If you have a remote control was produced after 2002 or there is no sticker
click here to use Sky's code look up tool.
Most SKY+HD Remotes are produced after 2002
1helpful
How to change from ntsc to pal on bravia kdl-40s3000 40 "
Changing this requires a change of the tuner. There is nothing inside the set that can make this change. There are external systems that can do this, but they are expensive (multiple $100s).
Bottom line is that this would require a change in the internals of the set.
Hope this helps.
Dan
1helpful
Green pixel lines
It sounds like a bad LCD panel but you would have to post a picture of the problem for me to be sure
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
