Question about Electrolux EIFLW55I Washer
Water will not drain. sewer line is not pluged. Customer service says I could have a plugged filter at the pump ( we have dogs). How do I get to the pump to unclog it. Model EIFLS55IIW woody
  • Official Brand Answer
  • 4,342 Answers
Hi agnes! Washing machines, including those built by Frigidaire, have internal pumps. These pumps help drain out the water from the washer tub between the wash, rinse, and spin cycles. If the pump is damaged or the pump pulley system is frozen/stiff, the water can become trapped in the washer tub. In both cases, the pump assembly needs to be replaced. You can check by looking for a few signs that a pump is dying or already dead.
1 Start the washer and wait for the washer tub to fill with water. If you do not hear water or hear a motor whirring, the washer motor may be dead.
2 Open the washer lid in mid-cycle. Note whether or not the inner tub is still spinning around. The inner tub is the inside surface of the washing compartment with many holes for water draining. If the tub is not spinning but the motor is running, it is possible the pump is dead. Check the pump pulley by removing the pump from the washer and trying to rotate it by hand. If the pulley doesn't turn freely and is frozen or stiff, replace it. Also, if the agitator is moving but the tub isn't, this is a sign the pump is dying. For front-loading washers, do not attempt to open the door mid-cycle. Look through the glass door. If there is enough water to come up against the door, the pump is malfunctioning.
3 Wait for the washer to finish its cycle. Open the unit. If water is still in the tub, the pump is likely dying or dead.
Posted on Sep 04, 2013
6ya staff
SOURCE:
What would cause a gurgling sound at the kitchen sink when no water is running anywhere in the house?
the waste disposal system for your house was installed by a person who was not competent to do the job and didn't make allowances for sufficient air pipes in the system or placed them on the wrong side of the traps
I would have an engineer inspect the installation to pin point the problem so that what you have doesn't occur and if it is installed contrary to plan and engineering requirements seek legal redress from the plumber that did the job
Nov 15, 2015 | Dishwashers
My GE gfwh2400loww washer, the pump filter needs to be drained every 1 or 2 times a wash is done..otherwise water stays in, and when you drain it, it smells musty and horrible. I checked the manual,
You should not have to clean filter . Check your hose for clogs ,follow the hose all the way to where it drains into the sewer line. If your sewer line is very high up the pump may not be able to pump out all water efficiently. So some water will flow back down to the pump. If there is a clog up high, the clog will not allow draining. These pumps are strong ,but not that strong. Please let me know what you find. GOOD LUCK FRIEND.
Nov 17, 2014 | Washing Machines
Main sewet line on 2 story hom
Well the main will be in the basement first snake the drain that's pluged but would use a plunger first chances are your haveing a problem in a bathroom drain if so remove the plug get something thin chances are full of hair
Jul 07, 2013 | Plumbing
WATER LEAK BOTTOM OF UNIT
If this is a central AC, the
condensation drips off the cooling coils into a pan. From the pan, it is suppose to either go into a drain directly or into a sump, which in turn pumps it into a drain. Dirt or mold frequently plug the drain out of the pan or the drain line itself. You need to clear the drain with a wire or forced air. If there is a trap in the drain line, it may be plugged. If there is a trap and the line is not draining from the trap into a sewer, then I suggest you remove the trap, which is intended to block sewer gas from coming up the drain line. If it doesn't drain into a sewer, there is no sewer gas to block and the trap is unnecessary. The credulous building code requires the trap, regardless of whether or not the unit drains into a sewer.
If you are talking about a window unit, the problem is similar - the water is being blocked from where it is supposed to drain. With a window unit the water is usually picked up by the fan that cools the
condenser (hot coils) on the outside of the unit. The fan sprays the water on the hot coils and evaporates it so it doesn't drip out of the unit.
Oct 04, 2012 | Goodman CKL49AR49 Air Conditioner
Water from toilet or sewer line bubbles into tub through drain.
Your sewer line is plugged downline from the toilet and tub... then the toilet backs up into the tub...
You will need to have the drain line cleaned to solve the problem..
heatman101
Aug 24, 2011 | Home
Won't drain
Please follow the steps provided bellow :
Fill washer with water and wait for the timer to get to the drain mode.
Unplug the washer from the electric outlet.
Open the case, and disconnect the water hose from the outlet of the water pump.
If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.
Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.
Reassemble hose from step 3.
Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
Reassemble washing machine case...you're done...
Aug 18, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Is it possible to contaminate the membrane and filters by placing drain under pressure in order to clear and forcing water out the overflow on the side of the faucet of the whre 25 Reverse osmosis system
OK, now I understand. First, on the Reverse Osmosis Membrane Housing Outlet Ports there is only a Check Valve attached to the Permeate (Pure Water) Port, not the Concentrate Port (Drain Water). The Permeate line is what fills the storage tank, so you don't want back pressure from the tank reversing into the membrane filter which could severely damage it. So, there is a high Risk for Sewer Water to Back-flow into the Membrane Filter and Contaminate it as it is discharging water to the sewer drain if there is any noticeable pressure restriction in the drain distribution manifold. Second, this is why "Air-Gap" Faucets are supposed to be used when installing Reverse Osmosis Systems. With an Air-Gap Faucet, there are three (3) attachments for tubing at the base of the faucet, and a small hole drilled out underneath the lever or handle of the faucet. The 1/4" pressurized drain line tube from the RO System attaches to the 1/4" barbed fitting under the faucet base, then a 3/8" drain line tube attaches to the 3/8" barbed fitting. So when the drain water is pumped up to the faucet under pressure, it returns to the sewer line under Gravity, or No Back Pressure. Then, if the plumbing becomes restricted in any way that the RO Unit can't drain into the sewer under gravity feed, the hole drilled in the base of the faucet allows the back pressure to be escaped to the atmosphere, and if necessary drain water out of the hole until the plumbing pressure restriction can be resolved. This eliminates the possibility of a reverse flow pressure situation from occurring. Hope this helps, and you can always visit us online at www.puresafe.com We have filter cartridges for all makes and models of RO Systems, and 1/2 micron filters that no one else in the trade is using at this time. Thanks, Victor
Aug 05, 2009 | Whirlpool WED6400S Electric Dryer
Sump pump drain
Storm sewer or rain water run off area. In other words , almost anywhere where it won't come back in.
Mar 12, 2009 | Genius Wayne Submersible Sump Pump With ...
Leaking water at the end of cycle
Watch your drain line in the wall when the final pump out begins.
May be a sewer problem.
Start a cycle. After the fill, advance to final spin and watch drain in the wall.
Feb 25, 2009 | Whirlpool Washing Machines
0E error
Product Laundry Washer
Symptom Error Codes
Sub Symptom OE error
Question Drain Problem Error.
Answer
Make sure that drain hose and drain filter are not bent or clogged. In case of there are objects in the drain filter, It might drain to slow or not at all. HOW TO CLEAN THE DRAIN FILTER 1. Allow the washer to cool down before cleaning the drain pump filter. 2. Open the lower cover cap with a tool such as coin. 3. At this time use a catch pan to prevent water from flowing onto the floor. Unplug the drain plug, allowing the water to flow out. When water does not flow any more, turn the pump filter open to the left. 4. Remove any foreign objects from the pump filter. After cleaning, turn the pump filter clockwise and insert the drain plug to the original place. Close the lower cover cap. If the drain filter is not clogged, you will need to call LG Customer Service at 800-243-0000.
Aug 18, 2008 | LG Washing Machines
Electrolux EIFLW55I Washer Logo
140 people viewed this question
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
