Question about Zebra ZXP Series 8 Thermal Card Printer
Ribbon color error code 5007 - Zebra ZXP Series 8 Thermal Card Printer
    New Friend:
Error code 5007 - anyone???
Posted on Oct 22, 2013
ZEBRA Ribbon color error code 5007? How to resolve?
Posted on Nov 05, 2018
6ya staff
SOURCE:
I have a fargo HPD 5000 and I am getting the error 91 stating the ribbon is out..i have changed and its still showing the same error. am I doing something wrong?
Hi Camille - that is indeed the error message for "ribbon out". This has a few possible causes:
1. Make sure you have the right ribbon for the printer. The standard color (YMCK) ribbon is #084051; if dual-sided, the standard YMCKK ribbon #084052; if monochrome/black print only, that is ribbon #084060.
2. Make sure the ribbon is loaded correctly. The spools are color-coded, so make sure the orange on the ribbon spool is in placed with the orange on the carrier - ditto for the blue.
3. Make sure you've changed the "ribbon", not the "film". The ribbon has orange and blue spools; the film has yellow & green spools.
4. Make sure the ribbon is loaded properly on the carrier - it goes the "long way" around the carrier, across the silver/metal rollers.
5. Try another new ribbon - they're RFID tagged, and occasionally an RFID tag is bad, missing, or corrupted.
6. Verify you have the latest printer firmware, to ensure all ribbon manufacturing site-codes (embedded in the RFID tag) are recognized as valid for your printer.
If you have continued problems, we can help with further support, including potential repairs. Good luck!
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com/
Feb 14, 2018 | Fargo Office Equipment & Supplies
Ink-ribbon error
The problem you are having is the unit uses various cartridges that the ink spools must match. You must have the correct cartridge with the ribbon you are using or you will get that error message. There are three types available from the manufacturer. P+ for the Photo ribbon, The Color Insignia for the Color Ribbon and the Versamax brand ribbon although i don't recall what the symbol is on that one. If you are trying to load a spool of Photo ribbon on a color spool that message occurs. Hope this explains everything.
Aug 19, 2013 | Teac P-55 Thermal Printer
I GOT COLOR RIBBON BUT THE PRONTO SED TO ME THAT A HAVE TO CHANDE BUT THE RIBBON IS NOT DONE YAT!!
Hello fabiogb_765,
Did you notice an error number when your printer tells you that it is out of dye film?
The error number is important.
Regards,
MC.
Jan 11, 2013 | Magicard Enduro/pronto Ymcko Color Ribbon-...
What is Kenmore double oven error code "F7" mean?
For the F7 error code:
Here is a test to find out whether its your control panel or control board:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
What color is your key panel? Black or White?
Aug 06, 2011 | Kenmore Ovens
Errore 000732-0001
getfile.asp?rid=1258 October 7, 2004 getfile.asp?rid=3215 Product : imageRUNNER C3200 Title : E732 and E733 Error Codes Problem :
Ongoing issues with error codes E732 and E733.
Solution :
Reseat the ribbon cables between the Reader Controller and the Interface PCB (FH2-6984-000 & FH2-6983-000. If the problem persists, replace the Reader Controller PCB (FG3-2570-000), and the Interface PCB (FM2-0036-000) at the same time. Canon USA, Inc. Systems & Technical Support Division
Dec 23, 2010 | Canon imageRUNNER C3220 Color Copier
I have a System Error Code 14-376 please help me
This code refers to a halftone pwb fail, if fault occurs when coming out if powesave I would suspect a lvps fault, other things that have can cause this error include front door interlock, vsel pwb, fuse 4 on distibution pwb, open circuit on 5v to ROS, faulty ribbon cable from IOT CPU to halftone PWB.
I would try first to reseat the PJ on the IOT CPU mainly p397 and p398 and pj403 ribbon cable, also dont overlook the front door switch as this will cause low voltage problems.
Sep 03, 2008 | Xerox DocuColor 12 Color Copier
Error code 754
It's very possible you are not installing the ribbon properly.
When loading a new ribbon on a Monarch printer, you must save the plastic ribbon core (it's butter yellow in color) from the previous roll of ribbon. The core is what the ribbon is wound up on.
Do not throw away this plastic core - you need it for the next roll of ribbon you load!
You have to move this now empty core from the back ribbon spindle and slide it on the front ribbon spindle. You then load the new ribbon on the back spindle and attach the ribbon end to the empty plastic ribbon core on the front spindle.
You CAN NOT just tape the ribbon to the front spindle. You must have an empty ribbon core to attach the new ribbon to. The printer will give a 754 error unless you have two plastic cores on the two spindles. It can also give a 754 error if the ribbon is not loaded properly, and also if you have a bad motherboard. There are no ribbon sensors, so that's never going to be a problem...
Jul 28, 2008 | Paxar Monarch 9850 Thermal Printer
Evolis pebble 3 ribbon problem
Hi, did you change the ribbon type at the printer properties? You must choose the black ribbon or monochrome in old drivers.
Jul 04, 2008 | Evolis Pebble 3 ID Card Printer Package...
Liteon LVW 5007 recorder problems
check with www.partstore.com and see if you can get a manual for your dvd recorder.i cannot tell off hand what to do the manual will.good luck or go to www.oxysearch.com for transfer of data.
Apr 02, 2007 | Lite On LVW-5007
Zebra ZXP Series 8 Thermal Card Printer Logo
3,150 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
