Y580, Fn doesn't work and neither does the control panel. The bar will move but nothing happens.
SOURCE: lcd brightness adjustment
1. Try to use an external monitor. Possible problem on the LCD.
2. Try to reinstall the graphics driver.
2. Do a recovery as the last resort.
SOURCE: Unable to adjust the brightness of display screen
bright ness buttons are indicted witha sun like mark . they r usaly used with fn keys look for that keys
SOURCE: Unable to change the Display Brightness
Click Start //Click Control Panel// Performance // screen brightness
SOURCE: BRightness FN control does not work. I tried
This looks to be a software issue. if the slider in the control panel is off, and it is not responding with the Fn key. then you should check the display adaptor in device manager. install the appropriate driver if needed.
SOURCE: I have a Toshiba Satellite
Hi
For those keys to work, you need the software utility for keyboard to be installed.
You can get it from Toshiba website
Please tell us your results
Good Luck
