Hi, I am in Melbourne Australia. Can I receive gem hd channel thru my dmr-ez48v. I haven't tried but I do have a hd monitor screen that I can plug the unit into. Also what does the hdmi on the unit do....
HDMI means high definition multimedia interface.
When connected to an HDMI compatible unit, an uncompressed digital audio and video signal is transmitted, enabling you to enjoy high quality digital video and audio with just one cable. When connecting to an HDMIcompatible HDTV, the output can be switched to 1080p, 1080i or 720p HD video.
Panasonic uses Viera link option between their video products.
When connecting with a Panasonic TV (VIERA) or a receiver equipped with 'HDAVI Control' function, linked operations are possible. [Linked Operations with the TV (VIERA LinkTM HDAVI ControlTM)]
Please use HIGH SPEED HDMI cables that have the HDMI logo (as shown on the cover).
It is recommended that you use Panasonic's HDMI cable.
Recommended part number: RP-CDHG10 (1.0 m/3.3 ft.), RP-CDHG15 (1.5 m/4.9 ft.), RP-CDHG20
(2.0 m/6.6 ft.), RP-CDHG30 (3.0 m/9.8 ft.), RP-CDHG50 (5.0 m/16.4 ft.), etc.
Non-HDMI-compliant cables cannot be used.
(the above is from the owner's manual of this model - page 40 tells you about linked operation using HDMI HDAVI control and how to set it up)
As for Gem HD, this unit has an SD (standard definition) digital tuner - it will not decode/receive HD channels. I should point out that 7mate also is a HD channel but is not specified as such in any menu or even their website. (I found this out by accident when I tried to record on timer 7mate one day and all I got was 'unable to decode HD channel' banner at the bottom of a blank screen)
Channel 11 is a SD channel - so this will work with your DMR-EZ48 as will all the other relevant main free to air channels (ABC/7/9/10/SBS). GO! is also a SD channel.
To be able to record HD to this combo unit you will need a HD set top box connected via its AV inputs. HDMI simply means you will get HD video quality from the combo to the TV, you will not receive HD channels from your HDTV to your DMR-EZ48 unit via this method.
