Question about GE JKP20 Electric Single Oven
'79 GE oven lower bake coil not heating after replaced w/switch.
The problem started last week with the arcing of the lower baking coil of our July 1979 combination (micro & oven model J - KP97G serial MF980755M)GE oven... I replaced the same lower coil that I previously successfully replaced in 2001. Except this time, only the upper coil functions in the Bake mode although the oven Clean mode works great. I just replaced the oven switch WB22X5123 as recommended in lieu that there was no connection being made between the 2 'Bake' terminals and no visible wire connection problem was visible. I tested the new coil to the normal 17.8 ohms although the power across the lower coil terminals was only about 40 volts...The thermastat unit contacts looked ok and I cleaned the copper contacts. (just a note that we have not had a continuous red light on the bake light for some time and we have adjusted the oven temp dial to 50 degrees warmer than desired with success for years...) We would like to continue using our current oven for at least 5 years when we may replace some of our kitchen appliances. Please help. Thank You.
  • 906 Answers
Good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
2 Suggested Answers
6ya staff
SOURCE:
Roipatrick
  • 906 Answers
SOURCE: '79 GE lower baking coil not powered in Bake cycle
good day,
kitchen appliances
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
No power to heating coils
h\ave you check for any damaged ono the themal fuse..?
Jul 09, 2008 | GE JTP45 Electric Double Oven
GE electric oven won't stay hot
Google GE electric oven Model number: ? Manual
Jan 15, 2018 | GE Ovens
Our ceramic cooktop, Frigidaire ES200/300 oven, baking element burst into flames, arcing and pitting the lower oven wall on Christmas day. We are trying to locate a replacement part number for the lower...
If the element shorted out and burned you can go ahead and replace it. With your model number you can order another on line like sites like sears or buy it at a local appliance parts store. Here's a link to sears. sears parts
Dec 26, 2010 | Ovens
Is it easy to replace the lower element on a jtp 15 GE oven? While the wife was baking last week, the lowere element burned out. Was wondering if I could replace it myself
Easy replacement. Make sure to unplug power or shut off breaker. remove 1/4" hex screw on back of element. Pull off female terminals or some have screws. Install new element the same way.
Mar 23, 2009 | GE JTP15 Electric Single Oven
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
Bizzare Oven
i will call ge technical and see if they have an issue after holidays would of you reply to me with a complete model and serial number
Dec 14, 2007 | GE JKP15 Electric Single Oven
GE JKP20 Electric Single Oven Logo
250 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
