Check on crt board green amp transister and associated ckt should be short. or green drive transister,or main jungle ic which drive green signal is sure defective, i had the same problem in rca 32 inch tv for all screen red,replacing chroma ic solved the problem.
My IS-TV040922Insignia TV have this yelowish screen.
It's not that it doesn't have picture or doesn't work. It works very well but with a yelowish screen stead regular colors.
The same thing happened to me. The screen will periodically switch from having a green tinted screen back to the regular screen.
I have the same problem...it just started recently...a yellowish green screen! HELP!!!!!
Same problem as the others my screen is green what's the answer?
Same problem here, TV was working fine then started getting a green picture
anyone tried the solution?
can you expand on how to perform this?
I have the same problem - screen is fine then turns "green" - tv is less than 2 years old. This has been going on for about a week.
My screen has the greenish tint to it. Sometimes the screen returns to normal, but only for a short time.
La pantalla se torna verde y luego con un tono azul vulve a la normalidad pero solo por un tiempo eso pasa hace 1 mes
