SOURCE: Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
SOURCE: 125FX (with FXhood) turns off while in use
may be overheat stat or fan check little hose at fan area for pinhole best of luck
SOURCE: I have a Bosch AquaStar AQ-125-BNG tankless water
there is a small dia copper pipe which has a thermal coupling on it the end of it sits in the flame of the pilot light,
if it fails which it does after about 25-15 months,it shuts down the gas burner
SOURCE: Pilot light goes out randomly on 6 year old Bosch
The pilot light can be blown out just by the main gas being ignited especially if the pilot flame is a little weak. Some times a bit of grit gets into the pilot nozzle reducing the flow and hence a weak flame. Try cleaning the piolt jet nozzle with a fine piece of wire. You may have to dismantle the jet nozzle to clean it properly.
SOURCE: I have a Bosch Aquastar 125ng with the water
i have an aqua star 125 ng an the pilot lights and stays lit but the main burners wont fire up when i turn the water on i have good water pressure so i kind of stumped and i just rebuilt the diaphram in it also
