FoodSaver Food Saver Vacuum Sealer SmartSeal V3460 Logo
Kathy Vogt Posted on Sep 02, 2013
The "tray full" light will not go off, so the unit will not turn on. The tray is empty and clean.
2answers
FoodSaver V3240: Lights flash,,,won't operate...what's wrong?
Pull out the long rubber piece on the top, clean any debris, replace firmly.
V3835 tray full light won't go out after both trays have been emptied and cleaned.
Hair dryer. Remove both tray inserts and dry thoroughly, paying special attention to the sensor area in the center of the upper tray.
1helpful
Keurig model B40 How do I empty the resevoir , I can empty the cold watet tank. We are moving so need to completely empty all water.
The water reservoir lifts out. There are two tabs on the side which lock it in place. You may have to pres on them to remove it. If you are wanting to completely empty the entire machine, I have found an instruction manual and have instructions for purging: Fill reservoir with clean water and replace on machine with lid on it. Raise and lower handle without K cup inserted. Wait for the red light next to "heating goes off.
The blue lights on the control center will begin flashing. Put a cup on the drip tray and press "Brew"
When finished, repeat brew procedure 2 or 3 times and inner tank should be empty.
Hope this helps, if it does, please place a vote for me.
Good luck with your move,
Handie Andie
Mar 28, 2011 • Vacuums
Roomba does not fill upper tray.
brushes are not turning, you can see this if you remove dust bin and start the roomba, remove brushes clean thoroughly removing yellow end pieces as well to remove trapped hair, re inbstall brushes and turn manually about 20 turns and re try cleaning, try this a couple of times
Irobot 4100 brushes do not turn & bin is empty but filter is full. does the roomba need a new cleaning head module?
Yes, it probably needs a new cleaning head module, if your bearings are clean and the brushes still don't turn.
Emptying the powerbrush
Gently
press the Quick Release tabs on the Clean/Solution Tank
and slide the tank off of the unit.
Grab the Dirty/Collection Tank and pull to remove.
While at the sink, remove the Tank Cap by turning
approximately 1/4 turn counterclockwise and lift
out the cap.
Empty the tank. Rinse the Dirty/Collection tank with
warm water.
Replace cap and turn approximately 1/4 turn clockwise,
until snug.
Slide the Dirty/Collection Tank into the unit. Replace the
Clean/Solution Tank.
The tabs on the side is what locks the tank on, if they won't release the tank, then you may have to take apart to get it off and replace the tank.
Top FoodSaver Vacuums Experts
ADMIN Andrew
ADMIN Andrew
goneforever.
Curt mueller
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
