SOURCE: wanted to put windows 7 ultimate 32 bit on. came
In order to step down to a 32 bit OS from a 64bit OS you will have to completely reformat your hard drive with the 32 bit os install DVD.
SOURCE: I have an Acer Aspire one and it won't let me
Generally - you simply need to right-click anywhere on the desktop that does not have an icon present, and select "Screen resolution". Adjust the slider as needed to obtain the desired resolution. If the resolution desired is not available, choose another that is close.
Digging deeper, you might want to investigate the "Advanced settings" to make sure that you've got the correct drivers loaded in the settings for both the "Adapter" and "Monitor" tabs.
Lastly, "Windows Ultimate x64" is the 64 bit version of Windows. The 32-bit version is referred to as "Windows Ultimate x86" If there are both 32-bit and 64-bit drivers available for your Aspire, make sure you get the correct version 32-bit = x86 and 64-bit = x64. The "x86" tag came from the Intel processor line up where the "x" represented the generation (8, 16 and 32 bit CPUs) and the "86" were the last two digits to indicate the instruction set used by the CPU like this:
8086, 80286, 80386, 80486, etc.
The 64 bit CPUs are not x86 family processors, so they do not carry the x86 tag. Please rate this reply if it was helpful to you - good luck!
SOURCE: i have dell inspiron but
Have you checked with Dell if your computer is upgradeable to windows 7 or not? It could be a hardware issue or a driver issue as well. Have you tried restarting the computer into the safe mode after the Windows 7 installation? If not then try that, because if its able to restart in that mode then its definitely a driver issue, else a hardware issue.
SOURCE: windows 7 ultimate geniune product key
How to check Windows XP/7 genuine or not
Microsoft Genuine Advantage Diagnostic tool : Download
Download the above software, Run it and press Continue to perform diagnostic.
At Validation status if it shows Genuine then your operating system is genuine otherwise not.
SOURCE: i need sound drivers for 8-ch audio
Rather doing a driver hunt http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 Note: it will find all of your outdated drivers This is a free driver solutions which will automatically search for and find the correct driver You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. It might take some time being free also http://download.cnet.com/2000-20_4.html Just type in what you want or need be specific you might have to try a few times to get it right. Tick in either the all software or the windows software box. IE: Motherboard name sound drivers
