1998 Chevrolet Cavalier Logo
Posted on Apr 13, 2009
1995 Cavalier Z24 Car Wont Start
So the story goes, I was driving my car all day, stopped to get gas just before I arrived at home, had to leave again about an hour later. I turned my key and the car made 2 clicking noises, which was an every start up thing, but nothing else, I turned the key off and tried to start the car a few more times with no success. I turned the key off and the engine began to turn over with the key off. I quickly removed the key and the engine continued to try and turn over, I put the key back in the ignition and turned it on. The engine then stopped trying to turn over, I tried a few more times after that, and it continued to turn over by itself when i put the key to the off position as well as with the key out. After a few times trying the engine finally turned over, I turned the car off to try again as a test, and from then on the engine will not turn over. Every time I try and start the car now it makes 2 clicking noises, a few humming noises, one from the alternator and one from the fuel pump. Any advice would be grateful Thanks
  • Anonymous May 11, 2010
    Hvae you looked into buying a new battery?, and changing the ignition switch.
Anonymous
Level 1:
  • Contributor 21 Answers
  • Posted on Apr 13, 2009
Anonymous
Contributor
Level 1:
Answers
21
Questions
0
Helped
18939
Points
69
You either have a bad solenoid on your starter OR a bad ignition switch as these are the only two things that can cause the symptom you describe... I lean to the solenoid first, RARELY does an ignition switch sieze up in the start position but it is a possibility. Several national chain parts stores can test the starter for you (GM starters have the starter solenoid mounted directly to the starter and you need to remove the starter to get to it, so you would take the whole unit in to test it... REMEMBER to disconnect the battery first!)
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 09, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
502
Points
My car was trying to start by its self while i was in my living room , ran out with a key, turned it off, it started one time but the starter keeps trying to start the car,smelled rubber or wire smoking, that went away and now the car wont start, i can jump start is with a screw driver crossing the solenoid to the starters other wire start right up when the key is in the on possition
1 Related Answer
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Apr 12, 2009
SOURCE: 1995 Z24 chevy cavalier wont even turn over...
obviously the altenator is running to earth inside ,could be a rectifier diode .change altenator and recharge battery
2answers
1990 Chevy Cavalier z24 shuts off and has trouble starting
sounds like a possble bad egr valve stcking open or then clutch in the torque converter is staying on
1helpful
2answers
1993 Chavrolet Cavalier it shakes badly in parking mode
Yes I have repaired both of these concerns on hundreds on 4 cyl. GM models most of the time the bad engine mount is the one on the passenger side of the car.And it is the TCC solenoid that gets stuck on.
1helpful
3answers
I have a 1990bmw 325i. i turned the car off one day. ran in the store. ten minutes later came out and the car wouldnt start. left the car. came back thirty minutes later the car started. drove the car 25...
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
88 cavalier has no spark
check the throttle position sensor,it may be stuck and it wont start unless its all the way back.Almost like trying to start it with the gas pedal down-which it will crank and crank but it wont start.
1helpful
1995 cavalier z24,quad 4,dies at random moments.
Have someone else see if their scanner will communicate, if not, this is a sure sign that the ECM has gone bad and will cause intermittent stalling. Normally I would recommend changing the crank sensor for this problem and it still may be the cause if you want to try it first, but it sure sounds like a bad ECM.
2answers
1995 chevy cavalier
Maybe you have a clogged Gas Filter, Or perhaps the Fuel Injectors are dirty? Purchase some premium Gas, see if it helps, If it helps and the problem temporarily goes away maybe the Mechanic or Auto Supply can help.
Do you have any enemys? Could someone have put sugar in the tank?
Wont start ...not gettin gas
check the fuel filter and also check the fuse for the sending unit and all of the vaccum lines and the one behind the throttle body as well
3answers
1989 cavalier z24
Have similar problem, seems to be too much pressure build up in the gas tank, when you loosen the gas cap, there is pressurized air comes out. If I leave the cap loose, the car runs fine
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
