Craftsman WeedWacker Gas Trimmer 25cc 2-Cycle Curved Shaft Logo
A
Anonymous Posted on Sep 01, 2013
How do you remove head to replace line - Craftsman WeedWacker Gas Trimmer 25cc 2-Cycle Curved Shaft
What id availability of replacement parts for a Colt line grass trimmer
Hi, Best go to the dealer and they can get you a replacement part or new trimmer head. Good luck.
Jan 07, 2016 • Garden
2helpful
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 • Garden
2helpful
How do you take off the spool head of a craftman weedeater and replace it with a precut line head?
You can remove the spool by pulling firmly on the tapper button to remove it. The spool will then be exposed and can be replaced. reinstall the button by snapping back into place.
2helpful
Need to remove fuel injectors to replace cracked
Unscrew the lines to the fuel injectors, there is no need to remove fuel injectors to replace a head gasket.
6helpful
2answers
How do i replace the head gasket on my Suzuki LS650
To replace the head gasket disconnect the battery, remove the tank, remove the rocker cover. Manually turn the crank shaft until the engine is on top dead center compression stroke and the lines on the cam shaft gears are even with the top of the cylinder head. At that point evenly loosen the bolts that hold the cam shaft. Do one cam shaft at a time. Before you remove the second cam shaft tie a piece of wire to the cam chain then let the chain fall into the hole after removing the second cam. Loosen the carburator mounts and slide the carburators back so they are free of the engine. Now you can evenly loosen the head bolts and then remove the head. Check the head and cylinder for signs of warping or why the gasket needs to be changed. When you replace the head gasket make sure the gasket fits over the guide pins. Reassembly is essentially reverse of the disassembly. After you get the head torqued to specs, you will be glad you fought that wire attached to the cam chain when you start to install the cams. Make sure each cam goes back from where you took it from and the lines line up like they were before you took them out. Don't forget to install a new gasket on the rocker box.
Prints have lines throughout
Sounds like the printer head is dirty and needs to be cleaned. If after removing the ink cartridge and cleaning the print head with DENATURED ALCOHOL NOT RUBBING ALCOHOL, does not produce clean prints with out the lines, you might need to replace the actual print head mechanism. The print heads do not last forever and need to be replace every so often.
Cheers,
Keith
3helpful
Remove head to replace line
turn unit upside down so you are looking @ the underside of the spool. On the side of the spool should be a hole which you insert a rod to keep the spool housing from turning on the shaft. Turn and head will come right off.
EPSON Stylus CX3810 thin white line in every printed line
Hi there the likely thing is that there is a small blockage in the print heads not allowing the jet to fire and causing a blank line. You could remove the print head turn it upside down using a soft cloth clean the print head also use a alcohol based fluid to aid you.
Try this if it's doesn't work then the print head will need replacing you will be able to buy online.
Thanks J
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
