When turning on Xbox 360 with all cable in my TV show 'Mode not supported' i have tried my friends AV cable and still doesn't show up i have also had my friends Xbox 360 Plugged in and it works fine What can i do???
For the most part, an XBOX will display a picture on the TV regardless of what the settings are. If there is no picture, it is most likely the cable or the XBOX output terminals themselves.
Since you have said that your friend's AV cable didn't work either, even though it did on his, we must assume that the problem is with the XBOX.
If the warranty is still on the console, call Microsoft and send it in. If it isn't either call Microsoft and see that they can do, or find an online repair shop that can help you.
If you need furthur assistance, feel free to ask. If this response helped you, please rate it!
Thanks!
Check to see if cable are connected properly, if not that see if it is set for hd where it plug into ur xboox
