SOURCE: 2002 peugeot 307 wont start
Sounds like a starter motor problem. Possibly a sticky solenoid. Try rocking the car or giving the starter and solenoid a hard bang with a hammer.
SOURCE: hyundai santa fe 02 diesel
my 2001 hyundai santefe won't start. I diagnosed it and had this code, P0340 camshaft position sensor mulfunction, I checked the wiring system, replaced the cam sensor, but still keep having the same code. can anybody help me out?
secondly there is no current to the injectors. What do i need to do
SOURCE: 2003 hyundai santa fe car alarm
I had the same problem a while back. What I did was disconnect the battery for a minute and I havent had that problem since.
SOURCE: Fiesta Diesel (Y Reg) intermittent starting(flashing immobiliser)
diesel ,,,just bypass the immobiliser ,20mins work
SOURCE: Engine won't start. Dash lights flash rapidly when key turned.
the battery says 12 volts but may be dropping to 4 or 5 under a load...i would suggest jumpstarting the car and see what happens.the battery should read in the high 12 volts and not less than 9.5 under cranking. the dash lights go out on your car when starting,and the alarm will go off ,and disable the ignition if the voltage is too low in cranking the car because the computer will shut it down and activate the anti theft.....check your battery posts are tight. best of luck
