Have you tried the instructions provided in this link:
http://derbyphotoscouk.blogspot.co.uk/2010/10/how-to-get-your-epson-perfection-1200u.html
Good Luck
SOURCE: i need a driver for the scanner perfection 610 for windows vista
As Epson does not have drivers for this Vista, have you tried the driver for Windows XP?
You can find them here
Hope this can help.
SOURCE: looking for drivers for epson
Vista x64 and Windows 7 x64 driver for Epson 1660 scanner is found here:
http://www.vistax64.com/drivers/185132-unofficial-drivers-epson-perfection-1660-scanner.html
SOURCE: Epson Perfection 1200 Scanner Driver Needed for Windows 7
I posted this for another user but i'll post it here too,
I remember looking for hours for a driver
for my Epson 1200 scanner back when I upgraded by dad to Vista 64 Bit,
eventually I found one. Just today I upgraded him to Windows 7 64 bit
and remembered I couldn't get it to work, luckily I was able to dig up
the driver I used for Vista 64. Worked great in Windows 7.
I
can't remember where I found it so I can't credit the person who made
the driver unfortunately, however i've uploaded it to Rapidshare for
you to download. Here is the link:
http://rapidshare.com/files/324940248/epsonScan_1.0_Per1200Win64eu.zip.html
Just open up the zip file and run the setup. :)
Hope this helps, Merry Christmas!
SOURCE: I would like to find a driver for epson perfection scanner 1240u
I had the same problem.
First solution: Use Ubuntu instead, it works great with 64 bit.
Second solution: Download the full version of vuescan from a torrent site. (This program has a driver that will work with thousands of scanners) The demo version puts watermarks in your scan. Why pay for a program that makes your scanner work when Epson should get their lazy ***** to work making drivers for 64 bit?
SOURCE: any chance of a driver for Epson Perfection 1200
RapidShare is dead.
I used this link today 7-24-2012 and it worked like a charm.
http://www.box.net/shared/5rxsn87mqr
A huge THANK YOU to the person who did the work that Epson
should be doing.
Without the scanner turned on, I downloaded the file, unziped it
and extracted the files. I then ran the .exe
After that I turned on the scanner and let Win 7 install the device.
Simple as pie.
