Try the Control Panel > ActionCenter > "Restore your computer to an earlier time." If this does not work go to the Microsoft web site and choose the "customer Service option or theTechnical Support dept. and ask them about your problem.
If you have the Word Install CD's, try deleting the Word software > reboot your computer and reinstall the Woer Software.
Or right click on any Word document and at the bottom of "Properties" choose the hidden option > click on apply then OK. Make sure that the Read only" option is unchecked.
I don't understand what you were trying to do in the control panel to fix problems access your Word docs. The error code you have is often given when there is a problem with writing to the disk or removable media due to insufficient space on the disk or media. You need to give a more complete and informative description of the problem if you want any possible solutions.
How to fix a Samsung Washernd washer error code. You can make this repair your self and in most cases without parts. Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain. When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
