SOURCE: Disk for Zip 750 Firewire is not readable
sometimes you get this problem if you have changed software version what software was you using before and are these zip disks off your comp originally or from another sourse you could try reinstalling the software that came with it or if dont have software you should be able to get it off the net hope this is some help ...............................................
SOURCE: Can not eject zip disk
I have the imoga 100 external zip drive and there's a pin hole on the front panel. that if you straighten a paper clip and stick in the whole, it should manually eject the disk.
SOURCE: When I insert a disk into the scsi zip drive it
Google-search 'IOMEGA CLICK OF DEATH'.
Their ZIP drives were famous for this untimely death.
SOURCE: zip drive makes only a clicking sound when disk is
Do a GOOGLE-search for "IOMEGA CLICK OF DEATH".
Their ZIP drives were notorious for suffering an untimely death.
SOURCE: I have a Zip 250
If the disk is unreadable this means that the format or the files extensions on it are not readable in the operation system you use..either are damaged or the disk itself is damaged or it wasn't finalized like it should ...If other disks inserted run ok than the disk it is damaged and it is nothing wrong with the drive itself..When it says to insert a disk this means that it is not seeing the disk at all and it sounds like a drive problem ..but if other disks are ok ..than it is just a damaged disk or in a format unreadable ..beware if it a cd unit ..will not read dvd-es..or if it a dvd kind will not read large dvd-es (dual layer) or blue-ray disks..
