Televison & Video Logo
Anonymous Posted on Aug 31, 2013
TV has sound, but no video. - Televison & Video
  • Anonymous Aug 31, 2013
    RCA 27R411T is the model, do i need a replacment part, and if so can i replace it myself?
neil schwab
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 53 Answers
  • Posted on Aug 31, 2013
neil schwab
Expert
Level 2:
New Friend:
Greenhorn:
Answers
53
Questions
Helped
5862
Points
136
CABLES ON ITEM ARE IN WRONG ORDER, TO TV ITEM IS SET FOR A DIFF DEFAULT CHANNEL, TV'S R CH 3 OR 4 AND MOST OTHER DEVICES TOO! MAKE SURE THEY ARE BOTH SET TO SAME CH. MIGHT BE WRONG CABLES, 'RCA'S ARE NOT TEH ONY INE NOW,. THEY HAVE Py Pb ETC. CODES TOO - WHAT INPUTS ARE YOU USING, VIDEO IN? COMPONENT? DO TELL
2answers
How do I hook up my 55 inch led tv to a stereo for better sound
In many cases newer tv's do not have an audio out, some have a headphone jack on the side (Small usually blue)
Otherwise if you are wanting to get better sound from a DVD / Blueray / Satellite / Cable box, You can put the audio from these devices into your sound system, then plug your sound systems audio out into the tv.
The video out from your devices will need to connect directly into the tv.
If using HDMI or S-Video that carries both audio and video, slitter / separation boxes are available, but usually degrade sound and audio quality.
The above would look something like
Cable box audio out (red / white) to Stereo audio IN. >> Stereo Audio OUT to TV audio in.
Yellow (Video) Cable from cable box then goes directly to the TV Video IN. Just make sure the audio and video cables are going to the same section (Some tv's may have multiple audio / video in's
DOES PANASONIC 42" VIERA TH-L42U5S" BROADCAST VIDEO FILES FROM FLASH DRIVE? WHEN I CONNECT MY USB DRIVE TO THE TV, THE VIDEO FILES COULD NOT BE RECOGNIZED BY TV, JUST MUSIC AND PICTURES CAN BE VIEWED....
No this TV does not process video files from USB. To improve sound quality reset the sound settings to midrange on all settings. Too much bass causes the sound to be muddy, especially on vocals
Hi I've connected the game to the T.V. it works, but when I connect the system through my surround sound system I get only sound coming through the speakers and no video.
is the surround sound connected to the tv video input? if so, did you put your tv on the right video/ input setting that the surround sound is on?
How do I get my Insignia 42" to show movies from my PC using an S-video cable?
Make sure your S-Video is hooked up.
Now navigate your way to the Display options.
Now either extend your monitor to fit your TV or move the primary display to the TV. Also make sure your input on your TV is set to S-video.
That should move your display settings to your TV. Also do the same thing for your sound if your computer still plays the sound.
Just go to your sound options and make sure your TV S-video is set to default sound and it should chance from your computer to your TV.
1helpful
I would like to run my TV sound out of my TEAC AG-D9100. Can I connect my TV sound output to the VCR/VIDEO4 input without a video input and then switch to VCR VIDEO4 to get the output sound? I have the...
Yes, and if you have a cable/sat/dvr box why don't you just run ITs best TV-related audio into the receiver without watering it down through your TV?
I'm not so sure that running the TV video through anything else serves any purpose. Once TV has it where else do you need it?
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
No sound only video on windvr3
go to your control pannel in sound
chose your windvr in input
Sound problem with recorded video.
Check your sound properties. It is probably defaulted to a low setting. Try raising the setting to one that says DVD quality and see if that fixes your problem. Hope this helps.
Toshiba 50HP66 Plasma TV
Found that video 1 and video 2 switching does not work. The switching IC was HOT!. Then found a third video input works but no sound. Hooked -up sound output of DVD player to amplified loudspkr and it works, I hate to throw away a 2 year-old plasma TV when TV and cable still works.
Thanks for the offer anyway.
Mike
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
