SOURCE: When using the lens on my Canon Digital EOS Rebel
try to use another lens.
the problem is still,i think malfunction is on the body.
If solved,,,,,error is on the lens.
k.
SOURCE: lens not communicating with camera
contact problem or lens diaphram blades problem. First try to clean the contact with the pencil eraser. If the problem isn't solved. send it to canon it should cost you about 100.00 to repar.
SOURCE: Canon 5D Mk11 with 24-105
error 99 is lens strip error...
you have to change strip inside the lens
SOURCE: I have an error 01, communication between the
Have you tried cleaning the contacts? Taking out BOTH batteries? (There's a button cell as well as the main battery.) If you have a second lens you can test, i'd give that a shot first.
Either way, probably need to have it replaced or repaired right away.
Finally, have you got the latest firmware version? The XS is currently
at version 1.0.5, which was released in April of this year. You can
download it here.
Also, could check this link: 50mm-lens-contact-points and the video, as reference...
If this choice dont solve and still the same error - ship it off to Canon for service.
Hope helps.
SOURCE: have a canon 17-85mm USM lens. when taking photo
The flat printed cables inside the lens unfortunately develop small cracks over the years and this causes the lens to fail. The repair is NOT easy, you have to tear down the lens all the way to it's base components and replace the flex cable on the aperture diaphragm. The cable and the diaphragm are available online, but again it's not a simple repair and most people should not attempt it themselves.
Thomas Drayton
Owner Darntoothysam com
