SOURCE: athens controls inc board for old blodgett oven (gas)
Athena still sells this product as a ttc001
call me at 610-729-1032
SOURCE: how to reverse the conveyor belt on a blodgett pizza oven
reverse the wires on the conveyor motor
SOURCE: Oven door is locked shut. How do we get it to
Try cutting the power to it. ALSO push in to relieve the tension on the latch while attempting to open it.
SOURCE: Have Blodgett Pizza oven canno read model or
Since you were not specific as to exactly what is shutting down, such as the gas or the fan or the conveyor, or the entire oven, I would look for some sort of safety device. An over temp device or something similar. I would also look for a wiring diagram that may be located on the inside of a panel on the unit.
Hope this helps some how.
SOURCE: My company has Blodgett Gas
The serial number is under the left side door behind the cover. Open the doors take out the two phillips head screws which go into the top of the lower cover, one on each end just inside the door hinge, the lower cover will remove to the front.
