SOURCE: Occasionaly the engine shuts off and won't start on JD gx345.
If the fuel pump is working correctly then the problem is between the tank and the pump. run a fuel line from the pump to a gas can. If the pump is working it will siphon the fuel into your filter. If the pump is fine then there is blockage, broken fuel line (sucking air), or something blocking the pick up inside the tank.
SOURCE: not getting gas to the carb
There may a screen in the gas tank that is plugged. Drain gas from tank...inspect with flashlight. Clean screen with aresol carb cleaner and gently blow low pressure compressed air backwards through the fitting
SOURCE: johndeere 345 keeps quiting 1996 unit 657 hrs, pin
Sounds like an ethanol problem.Try some carb cleaner,if that wont help,rebuild on the carb would be the next step.
http://schematicsdiagram.blogspot.com/2012/01/coolant-temperature-sensor-dies-again.html
Where to Add Coolant?
http://repairhelpcenter.blogspot.in/2012/06/2000-daewoo-lanos-where-to-add-coolant.html
Blue Water Warning Light on
Dash?
http://whatisbyme.blogspot.in/2012/07/blue-water-warning-light-on-dash.html
