Garden Logo
A
Anonymous Posted on Aug 30, 2013
Have a cs3500 flowtron mulcher/shredder. need brushes for electrical armature on the motor. CS3500 model
5 Related Answers
Anonymous
  • 5158 Answers
  • Posted on Mar 19, 2009
SOURCE: blades for mulcher shredder
http://www.ryobi.com.au/
Anonymous
  • 7 Answers
  • Posted on May 15, 2009
SOURCE: Flowtron Leaf-Eater Mulcher LE-900F
Shot in the dark here. If the mulcher is tripping and needs to turned off then back on, it's defective and should be replaced. If the circuit breaker in your house panel is tripping, try to use different circuit on a 20 amp circuit breaker. If your using a plug that is controlled by a GFCI receptacle or breaker, move to a different plug. GFCI receptacles tend trip when motor loads are applied. These are my best guesses since I'm not sure what exactly you are reseting.
Anonymous
  • Posted on Jun 29, 2009
SOURCE: circuit breaker
I was able to get a replacement 5 amp MB-1 push to reset circuit breaker for my Flowtron LE-900 directly from Snap Action http://snapaction.net/ for no replacement cost and no shipping/handling cost. No one at Snap Action enquired as to what it was for, age, warranty, etc. (their MB1 product description indicates it to have a lifetime guarantee). I just had to mail them the defective original breaker - took about 2 weeks to receive the replacement.
Brett
Anonymous
  • 172 Answers
  • Posted on Jan 16, 2010
SOURCE: Flowtron LE-900D Leaf Shredder- Spinner flies off.
The screw is a common one, Make sure it is at least a grade 5 or grade 8. The o-ring may be another matter, but should be available at hardware and most definitely a hydraulic hose shop would have it.
Testimonial: "Questions answered! I think I can move ahead from here."
vincob
vince janis
  • 718 Answers
  • Posted on Mar 12, 2011
SOURCE: I have an old Flowtron
You can't chop wet leaves, and is it plugged in?????
It does not stop running
Commutator bar connected to the armature of the motor are damage, through which electrical connection is made (by the brushes) and which ensures that the current flows as direct current.
So solution buy a new motor or rotor/ armature
Regards,
Engineering Nicolaas
1helpful
The motor burned out after one year of use. It was bought in Oct 2009. This year in Oct. it burned up in about 10 min. How can I get a replacement motor? I took it apart, cleaned it, reassembled it...
I would recommend contacting the manufacturer. The warranty was 1 year. If you are at 13 -14 months, I would ask Flowtron for some help in getting it replaced. Sometimes manufacturers are willing to split the cost of a repair that is near the warrany end to help keep a customer satisfied. It is worth trying.
Good luck.
FLOWTRON OUTDOOR PRODUCTS
15 Highland Avenue
Malden, MA 02148
Telephone (781) 321-2300
Fax (781) 324-8403
Parts & Service: [email protected]
Sales: [email protected]
1helpful
I need a replacement spinner assembly for an older Flowtron Leaf Eater -- 800, I think. Any suggestions?
Go to www.flowtron.com. There you can find the parts you are looking for like ler-500 spinner assembly for $20.95.
Good Day.
Where could I get a replacement motor for a LE 700-1 flowtron
go to www.flowtron.com and call their customer service. That is what I had to do.
Good Day.
1helpful
2answers
How do you intall the cutting string on a Flowtron leaf eater?
I have an electric weedwacker which may be different. In the leaf wacker there are four small holes very near the center screw on the revolving shaft. These holes form two small tunnels. cut two pieces of line (10-12 inches) and stick one through each tunnel. Center each line, put the two ends together and poke them out through the small hole on the edge of the rotating shaft. You end up with two sets of plastic line facing out from the central shaft. Flowtron may be different. Good luck.
5helpful
2answers
Circuit breaker
Brett
Top Flowtron Garden Experts
Jay Finke
Jay Finke
john h
Are you a Flowtron Garden Expert? Answer questions, earn points and help others
