SOURCE: Canon Mp 610 error u052 incorrect print head
Hi I have U051, and U052 coming up, I did what it said to do press ok if that doesn't work turn it off, now it is continuously going to these problems. What do I do.
SOURCE: incorrect printhead
It just means that the printhead is defective, All of the Canon machines say that when the printhead goes out.
SOURCE: U052 prnt head is incorrect install the correct
You can check that it's installed properly, after that all you can do is replace the printhead. They are like a light bulb and burn out when you least expect it. If you printer is less than a year old Canon will replace the printhead, after a year you have to buy a new one. Anywhere from $60.00 to $100.00 The part number is on the side of the printhead, the number starts with QY6, the numbers after that are the actual part number.
SOURCE: My canon MP610 shows an error message U052 Incorrect print head
http://www.buzzillions.com/review/canon-pixma-mp610-multifunction-photo-printer-review-2458903?prRo=0&reviewSortBy=mostHelpfulFirst&prRpp=1
you wont like what you find. lol .
apparently if you call cannon support they going to tell you its a U052 is a temperature sensor error. and not the print head error. someone musta did some bad programming. lol
try returning the cartridge if its not a canon specific cartridge - and get replacement - try that - but i doubt its going to work - i would call about a new one (print head that is - they will also apparently send you a new print head.) as i have read up on
hope this helped
x404x
Testimonial: "Thanks for your quick response - I thought there was a resetting tool available so I can at least remove the message and get printer going."
