My Nikon D80 doesn't recognize any of my SD cards anymore, i.e. number of pictures is not displayed in LED in either On or Off position, and the colour screen does not work either - no picture playback and no menu. The other functions on the LED still seem to work, but not sure if pictures taken are now actually saved on the SD card. Swapping cards, replacing the battery and using the Reset button don't fix the problem.
This happened after I used someone else's SD card from their Kodak Easyshare camera in my D80 in order to download their pictures onto their PC (as they didn't have their own USB cable)...
Does anyone have advise on how to fix this problem? Thank you!!!
SOURCE: Camera stuck when using memory card
hi, i had a problem with my camera where i put in memory card and it said 'out of memory' i took the card out turned on camera went to set up mode and found one that said 'rest to factory defaults' pressed that and then put card in and all ok, might be worth a try :-)
SOURCE: Nikon D80 Exposure Count
Could it be that you are set in the "highlight" view? Use the round selector in view mode to change the views.
SOURCE: Nikon D80 SD Card slot problem
Is it slightly thicker on the contact end, Or is something stuck on the flat corner? try getting a needle and picking out any plastic that could be stuck there. Is the card under warranty?
SOURCE: my nikon d80 f number keep blinking. what should
The "fEE" error indicates that the camera is not communicating with the lens. The lens may not be attached to the camera properly, or if it has an aperture ring, it may not be set to f22 (or the highest aperture number of the lens) - which is normally marked in orange. Select this aperture and lock it using the aperture locking switch to prevent this from occuring again.
SOURCE: Nikon D80 'error' and 'clock' message
La batería del reloj
El reloj de la cámara funciona con una fuente de alimentación independiente y recargable que se carga si lo necesita
cuando la batería principal está instalada o la cámara se alimenta mediante un Adaptador opcional de CA EH-
5. Dos días de recarga proporcionarán al reloj la energía suficiente para aproximadamente un mes. Si parpadea
en el panel de control, la batería del reloj está agotada y el reloj ha vuelto a la hora de inicio,
2006.01.01.00:00:00. Ajuste el reloj con la fecha y la hora correctas.
Nikon Technical Support
8AM - 12AM (Eastern)
7 days a week
1-800-Nikon-US
1-800-645-6687
Thanks fblock for your comment.
I've contacted Nikon in the meantime; apparently the USB connection caused a voltage issue and the processor needs to be replaced.... ouch!
I wonder if there's any chance your firmware got whacked. I'd contact Nikon support to see if you can re-install the formware on the D80.
