Konica Minolta DiMAGE Z6 Digital Camera Logo
A
Anonymous Posted on Aug 29, 2013
Konica Ev-jetsetter System Error #9 - Konica Minolta DiMAGE Z6 Digital Camera
My printer Konica Minolta bizhub 165e
There is no 'ee102'. Call for Service.
C5102
Description: Main motor malfunction • The main motor (M1) lock signal remains HIGH for a continuous 1-sec. period at any time 1 sec. after the main motor has started turning.
Causes: Main motor (M1) Printer control board (PRCB) DC power supply (DCPU)
Remedy: 1 Check the connector between M1-PRCB CN6 for proper connection and correct as necessary. 2 Check M1 for correct drive coupling and correct as necessary. 3 M1 operation check. PRCB CN6-7 (LOCK) 9-D 4 Change PRCB. 5 Change DCPU.
CC102
Description: Controller - engine connection failure • The engine control system can not communicate with the controller.
Causes: Printer control board (PRCB)
Remedy: 1 Turn OFF and ON the power switch. 2 Change PRCB.
https://www.google.com/search?q=Konica+Minolta+bizhub+165e+error+code+ee102
1helpful
I have error code 9, no one knows what that code is?They say there is no listing for code 9
Error 9 possible Solenoid Brake Trip
The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure all the system connections are secure.
I have a konica minolta c450 and it displayed error c-d 370. I cleared it using 0-7-1-3-9 as instructed but on switching on the machine,on the screen it asked me to enter serial number and call ser
Code is for NVRAM Data multiple errors, You need to have the machine Firmware updated, only available through Konica Minolta secure web site for dealerships and KMBS, You need a tech you can not find firmware on the internet Konica Minolta protects their copier operating systems
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Well want to know the serial number of the machine and require the firmware be properly installed, Who instructed???????
22helpful
5answers
Konica minolta pagepro 1500w toner low error
recharge toner powder. 'BROTHER' toner powder is suitable for it.rate 100 Rs. only.
1helpful
I was having a Watson Client problem... and today I get: Exc in ev handl: Error: Bad NPObject as private data! What's up with this, now! Still having Watson Client problem and can't open Word! Help
This is a virus ..I suggest to reinstall the program ..and remove the old one completely ..If this will not fix the issue you will have to reinstall operation system to fix it for good.
4helpful
2answers
My nokia e5 has problem such system error, after used wifi to surf internet.once it happen, phone will be hanged. Do i need format this phone?.
hi jaboo_my ! im royal453 ... if u ev creat a backup file then run ur backup restore and slove ur prblm simple and best bcoz i ev had same prblm yaster day so i run restore backup file and slove it ....
Oct 29, 2010 • Cell Phones
Konica 7020 copier
35-9 is a low temperature error in the fuser.If the fuser has a problem it will not make a copy period.Sorry. Mrbonz
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
