There should be a tiny hole that you can get a paper clip through on your DVD this hole leads to a manual release mechanism that should open the DVD drawer. I hope this helps
I had a portable DVD player shinco sd-1250 when i turn it on and put the disc then when about
6 seconds the screen turn off .but the disc still playing and still have a sound.i'll find out when i press that little white pin button under the screen ,the screen it turn back on.then same thing happened in about 6 secs it turn off the screeen again.can anyone help me what the problem couild be.
It is a bush dvd 2080 which sorry to say dosnt have the hole, looks like I might have to buy a new one thanks anyway
Just so ppl know ended up taken the back off and found that the dvd had slipped took it out, put back on again and switched it on all fine.
Thanks for the tip. DVD jammed, took the back and cover off, took disc out of drive and now it works fine. The disc would not operate on my computer but did work in different player(Sony).
hit the remote eject button by accident and rehit it before tray came all the way out. hit eject again and put the DVD in. Blue screen came up and attempted to play after it said it was loading. Wouldn't play. Couldn't get it to eject and shortly thereafter couldn't even get the blue screen to come up anymore. It's the S99 player and I don't see a hole to stick a pin in. Just checking to see if anyone has had this problem or if I should just take the cover and back off and see what I can do inside.
