You didn't indicate the type of phone. Using the google account registered on the phone becomes a problem since in nearly all cases the data connection on the phone was left OFF. You may know your account and password but the phone isn't connecting to the internet to confirm. You are now left with the only option of hard resetting the phone and obviously you will lose all the contacts and installed applications too. But that is not a problem. If you had synced your contacts to your google account, once you register into your account again, all your phone numbers will be available again. Always be syncing your contacts with your google account. Newer phones models can be recovered by a technician without losing anything.
SOURCE: Hi, I need help, I have SAMSUNG Galuxy S (I9000),
Do this but make sure you may wan't to lose files:
1. Turn off the i9000 phone or take out the battery and reinsert it.
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 MATER RESET
Done!
SOURCE: Only incoming calls can be
Hi,issues like this involves Unlocking your cell phone...
When you click on wrong pins, and you forget your pin number, the phone will get to a lock mode..
Trying to unlock it manually will not be possible at that time,because your cell phone will be un acceptable..
At this point in time, you will need to unlock the phone..
There are two methods in unlocking the cell phone..
!. Going to a local cell phone repair store around your area..They will help you unlock it..But it will cost you some money to unlock..
!.Also Through the internet. There are some links on the internet..Allyou will need to do is to give your phones IME..number, make and the model of the cell phone...
Below are some links you can use to unlock the cell phone..
http://www.unlocker.com.au/
http://www.mrunlock.com/
http://www.askstudent.com/hacking/how-to-unlock-a-cell-phone-for-free-and-get-unlock-codes/
Hope it helped..
SOURCE: forgot username and password for my phones google account
Give your phone to the company's service center, they would solve your problem.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
