Turn off the system at the breaker,
Undo bolts for housing and separate the motor from the pump to access the impeller. Some styles of motors have a screw that is reverse threaded holding the impeller in place, if it has one , remove the screw. Once you have access to the impeller you can use a big pair of channel locks to turn the impeller. Take off the back cover of the motor or remove the plastic or metal cap that is covering the shaft. Use a wrench to hold the back end of the shaft as you unscrew the impeller.
