Home Security Logo
Jim woods Posted on Aug 29, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My GE doorbell ringes when neighbor pushes his doorbell. Help
Van Allen
Level 2:
Sergeant:
  • Expert 282 Answers
  • Posted on Aug 30, 2013
Van Allen
Expert
Level 2:
Sergeant:
Answers
282
Questions
Helped
83565
Points
717
You have to change the frequency so they won't do that.
4 Related Answers
Anonymous
  • 4736 Answers
  • Posted on Jan 16, 2011
SOURCE: everytime somebody rings my neighbors
It appears that you and your neighbor's wireless door bell are on the same radio frequency. You or your neighbor will need to change their base station (were the sound come out of) unit. If you or your neighbor still have their Owner's Manual you can find out how to do it in the Trouble Shooting Section. If that's not available, remove the cover, if necessary and you will find a small panel board with a series of movable slid switches (they are very small) . Moving those to a different position will change the frequency. The inside of the back cover should have instructions on how to reprogram it. DESA International bankrupted over a year ago, but some manuals in a pdf format are still available on line. Try http://www.desatech.com/ as there may be an Owners Manual that's still available. Different divisions of DESA International were sold off to other companies during the bankruptcy, so you may be led to another site. Good luck.
jason
  • 905 Answers
  • Posted on Dec 29, 2008
SOURCE: my pushbutton doorbell activates my neighbor's chime
in the chime box and remote you can change the setting for the remote signal that is picked up( refer to your manual for the correct settings) these will be a set of pin connections in the chime box and in the remote switch that will have to be set to another selection
Anonymous
  • 4736 Answers
  • Posted on Feb 17, 2011
SOURCE: my qireless desa doorbell rings
Here is the website that will explain how to change the security/frequency pins.
http://www.heath-zenith.com/servsup_disp_faq.cgi
Lynn Nohos
  • Posted on Nov 08, 2011
SOURCE: JUMPER SETTINGS FOR SL-6151-RX-A
http://heath-zenith.hcents.com/data/manuals/598-1034-02.pdf
My Blyss doorbell won't stop ringing. I have changed the batteries in the chime and tried various suggestions., cleaned the terminals in the bell push.Help please
If your Blyss doorbell won't stop ringing, there are a few steps you can try to troubleshoot the problem. Here are some possible solutions:
  1. Check the wiring: The first thing to check is the wiring of your doorbell system. Make sure that all the wires are securely connected and that there are no loose or damaged wires. You can also try disconnecting the wires and then reconnecting them to see if that fixes the problem.
  2. Check the chime: If the wiring is fine, the next thing to check is the chime. Make sure that the chime is properly installed and that it is not damaged or loose. You can also try removing the chime and then reinstalling it to see if that fixes the problem.
  3. Check the bell push: If the chime is working properly, the next thing to check is the bell push. Make sure that the bell push is securely installed and that it is not damaged or loose. You can also try cleaning the terminals on the bell push to remove any dirt or debris that may be preventing it from working properly.
  4. Check the transformer: If the bell push is working properly, the next thing to check is the transformer. The transformer is a device that supplies power to your doorbell system, and if it is not working properly, it can cause your doorbell to ring continuously. Make sure that the transformer is securely installed and that it is not damaged or loose. You can also try disconnecting the transformer and then reconnecting it to see if that fixes the problem.
If none of these steps help, you may need to contact Blyss customer support for further assistance. They will be able to provide more specific troubleshooting steps based on your particular doorbell model and setup.
1helpful
Why does my Desa doorbell model WA220-UK not work , fresh batteries in both button and chime unit?
It is a guess, but wireless doorbells have adjustable frequencies so that your neighbors door bell button doesn't ring yours as well. My guess is that the bell push and the chime unit are mis-matched. Do you have a manual? I can't find one.
https://www.google.com/search?q=desa+doorbell+model+wa220-uk+pairing+mode
Rind doorbell doesn't stop ringing
it is possible that the doorbell button is sticking down and keeping contact - so the doorbell keeps chiming.
My Byron door bell has started ringing itself at random times - not welcome at three in the morning
It is NOT random.
You have a ghost visiting your house.
(or a little rats azz neighbor kid)
Replace any batteries. Low batteries can cause false rings in wireless doorbells, too.
I still think it is ghosts, however.
My 202 doorbell does not "react" if the button is pushed AFTER my neighbor unlocks his car by using his remote key. Can I change the frequency range of the doorbell?
look for a cover that has small switches under it. You can change frequencies there. You must match the door button the same way .
Just a thought if the bell is wireless your diagnosis may just be coincidental, but look to at swapping out the battery. can you press the bell, say 5 times one after the other ok? Batteries sometimes recharge slightly between presses, maybe just pressing it twice once after each other doesn't work.
4helpful
I just solved a similar problem with mine. I found a PDF of the instructions for changing the frequency and the tone: http://heath-zenith.hcents.com/data/manuals/598-1034-02.pdf
8helpful
My doorbell also ring neighbor's bell
Change pin configuration on plugin bell and the remote.
The pin configuration should match
My pushbutton doorbell activates my neighbor's chime
Top Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Home Security Expert? Answer questions, earn points and help others
