SOURCE: QUANTARAY FOR MINOLTA AF 70-300MM compatibility
Usually mounts are unique to a camera manufacturer. There are exceptions. Sony has the Alpha; lenses for the Konica-Minolta are the same mount. Your AF (autofocus) lens will work on it. You might also consider picking up a Konica Minolta 5D or 7D.....they're no longer made and hence are cheaply had.
The MD and Rokkor lenses won't work on the Sony Alpha.
THIS IS A CHEAP LENS (<$50 VALUE) SO I WOULDN'T LET IT DRIVE YOUR DECISIONS!!
SOURCE: My Nikon D300 doesn't recognize the 55-200 AF-S DX as a cpu lens.
you call the computer expert to your home and then tell him this thing. he will give you the full idea about it. from my side it is the camera body.
SOURCE: I need the Picture schematic for my AF-S DX NIKKOR lens
hi i am SAGHA from mumbai,I do repairing from last 15 years. If I would have thought of repair manual for every camera & lens i would have one truck full with manuals.But practically speaking a littlebit of knowledge,lots of experience & very important high grade of your logic level,good memory & at last presence of mind these qualities will make you successful & perfect repairer.So follow these, go from mount side of the lens remove screws,distinguish them accordingly,keep them sequentially while opening,observe their locations minutely even before opening them, you will be sucessful definitely.I am giving you my key of sucess.Just follow & let me know.ALL THE BEST.Do not forget to vote me if you like it
SOURCE: cameras compatible with Quantaray AF 70-300mm lens
Depending on how new your Minolta SLR film camera was, the lens may or may not work on a Minolta Digital SLR. In many cases, a lens with the correct mount (in this case, a Minolta mount) can be used on the same brand of camera in the digital format.
One thing you should know is that DSLR sensors are, generally speaking, smaller than the size of a 35mm film negative. Long story short, that means that your lens will have a magnification factor on the DSLR. Usually, it is in the range of 150%, so a 70-300 lens from a film camera would cover 105 to 450 on a Digital SLR.
To be sure about the mount, you'll need to seek advice specific to Minoltas -- probably best to take your lens to a local camera shop and see for sure if it fits and what features will work (aperature, auto-focus, etc) and which won't work on the DSLR.
SOURCE: Will my quantaray tech-10 NF AF zoom lens (for me
Yes, with caveats. The autofocus won't work on D40/D60/D3000/D5000. The metering may not work in all modes on all cameras. Since you didn't specify which camera, I can't give you a better answer than that.
I have 30-year-old Nikon lenses working fine on my D90, but without metering. And the old lenses date before the invention of autofocus.
