SOURCE: Element FLX-2611B won't turn on. The red light is not lit
Just because fuses are intact does not mean it is not damaged. Sometimes a small spike of power does not blow a fuse but damages Transformer windings Before the fuse! If there are no lights picture or sound think powersupply transformer primary.
SOURCE: Element tv.. model # ELCHS261 stopped working
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
SOURCE: element stuck in standby and wont turn back on.
you can unplug the power cord and drench the power and after go ahead and plug in back the TV and try to start it
SOURCE: my element lcd tv model number flw1920b just stop
Two capicators on the power supply fail. C300 (680uf 10 volts) and C303 (1500uf 10 Volts). With a little electronics no how and a soldering iron you can have it up and running in a couple of hours. Parts at Digitkey (P12365-ND) and (493-1500-ND) Hope this helps.
SOURCE: Element 32" TV does not
Hi.
If the TV stays in standby and does not wake up, then the TV has on protect mode after detecting a fault.
When this happens higher voltages from PSU get shut down to prevent further damage
Try disconnecting power cord for about ten minutes, restart the Tv with no cables attached.
If that does not work, then there is an internal problem, PSU, main board and inverter must be tested.Here a description of general procedure:Testing LCD TV.
Unless you are a technician, if disconnecting power does not fix the problem, better calling support.
The best way to contact an authorized technician is
by ringing the number listed on the owners manual.
Parts Here:
ShopJimmy flx3711b
