When i hit the power button on my camera a little green light flashes then beeps and on the screen it says lens error, restart camera. I have tried taking out the battery and puttin it back in it does the same thing and i was just taking pictures on it so i have no clue whats going on. please help i'm getting ready to go on vacation i need my camera.
i have the same problem. when i switch on, the green led is light on, after 2 seconds it beeps 6 times, then the message on the display in german: Objektivfehler: Kamerastart. The Modell: DIGITA IXUS 70 AiAF Thanks for any Help.
You can't post conmments that contain an email address.
Your camera has a lens error, as you stated. The lens is jammed and needs to be replaced. Don't bother going to a store for help, they will just tell you to send it to Canon.
We can replace your lens for about $75! We are an affordable digital camera repair business; if we can help please let us know.
Either the motor has failed on the lens or the lens is blocked from moving, either because of a broken part or debris lodged in the mechanism somewhere. If removing the battery from the camera for 30-60 minutes to allow it to reset doesn't cure the issue and you can't see any debris or damage to the lens area you'll most likely need to send it in for repairs.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
I had the same problem and fortunately for me it was simple to fix. I gave it a little push & twist on the lens and to my surprise the lens retracted and now the camera works fine. Good Luck!
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
