I added two speakers (from 3 to 5). When I turned on the receiver I heard a popping noise and smelled the typical "electrical burn" odor.
The unit will turn on but only for a moment. The manual makes it sound easy to "reset to mfr specs" but the given resolution won't work for me because the unit has on before I can do the next step.
Ideas are welcome.
With the unit unplugged, remove the top cover and use an ohmeter to check the 10 power transistors on the large heat sink; Q6050 thru 54 and Q6060 thru 64. If you find blown transistors (R<1 ohm from E to C) you'll need to replace them. Also check the large ceramic current sharing resistors, R6100 thru 04 next to the output transistors. These are dual 0.22 ohm, 2W resistors that typically fail open if overstressed. These are both common failures resulting from overloading the speaker outputs that will cause the proctection circuit to shut down the power supply at turn on. Good luck.
