I have an A O Smith 1 HP pool pump motor. I have disconnected it from the pump (Jacuzzi Magnum pump) and am trying to put it back on but I did not tag the wiring. What I need to know is which wire goes where. There are three wires, 1 each, green, red and black (the shortest) On the motor is L1 and L2 connections and then above them there is another screw where a wire goes. Any idea what goes where? BTW, this site forces you to type in an exact brand, model but the site does not contain the one I have so I picked the closest one.
1.Pump not primed
2.Leakage of air into suction system
3.Impeller clogged
4.Valve in suction or discharge line partly closed or suction or discharge line partly plugged or too small. 5.Plugged basket in skimmer or hair in lint strainer.
6.Dirty filter.
Yes, the screw above is on the metal housing. I will try the green wire there and let you know. Thanks. I guess L1 and L2 it doesn't matter red or black. Will try later.
All is well, thanks.
need wiring diagram for the pump... the pump has 3 wires and the wire running from the house has 4
