SOURCE: Compaq Evo Motherboard
This mobo appears to be an MSI build and should have IDE drives attached.
SOURCE: reset motherboard bios
Both solution are correct in removing BIOS password, but sometimes removing the jumper when the computer is off wont remove the BIOS password while removing the jumper while the computer is on is definitely fine and 100% it will remove the bios password just like Voodoomox has said if you haven't tried it Tbirdfan1 you can do it in actual to prove that it wont damage the computer, After the BIOS password was remove select CDROM as the primary boot device then save the change the computer will reboot put the Opearting system installation CD then continue formatting and installing the system...
Hope that helps........
SOURCE: the number of mb ms-6541 ver. 1.0 compaq evo 310m
Boot up and go into bios and disable password.
SOURCE: How can i clear the
remove the cpu cover look for three pin near the cmos remove the jumber connect it with the pin which is free and restart in some motherboard the cpu wont start dont panic remove the jumper and replace it in earlear position and restart this clear the bios password
