If your Vermont Castings remote is burning through batteries quickly, there could be several reasons for this issue:
Weak signal: If the remote is having trouble connecting to the receiver, it may require more power to send the signal. This can drain the batteries quickly. Try moving closer to the receiver or replacing the receiver's batteries.
Short circuit: A short circuit in the remote can cause it to draw too much power and drain the batteries quickly. Check the remote for any signs of damage or wear and tear, and try replacing it if necessary.
Battery type: Make sure you are using the correct type of battery for your remote. Using the wrong type of battery can cause it to drain quickly.
Remote programming: If the remote is not properly programmed or is programmed for a different device, it may require more power to send signals. Check the remote's manual for instructions on how to properly program it for your device.
If none of these solutions work, it may be best to contact Vermont Castings customer support for further assistance or consider replacing the remote.
I never encountered this problem, but if you turn off WiFi when not in use the battery lasts longer. Also go to settings, battery, and check what is using the most power.
First thing is to check the power supply... dead battery or power adapter will be enough to start unit but quickly give out and turn off. If unit uses Alkaline batteries, do NOT try to use rechargeables as they run lower voltage and fail quickly, especially as they age.
sorry you are having trouble. No quick fix. It sounds as if the battery is dead and the AC Chargeris bad. Most likely the AC Charger is bad and not charging the battery. Take the charger to someone with a voltmeter and ask them to check it. Let me know if you need more info.
On most mice, you cannot shut the power off to them without removing the batteries and they will run down rather quickly. There is really nothing you can do unless you buy a mouse with a shutoff switch like my Logitech or use rechargeable batteries or just shut the computer down. Sorry.
Dale
